Hi All, As I'm new to this forum apologies if this has already been discussed, My CD player in my 04 Berlingo has stopped playing, I've tried
CD cleaner disc but no joy, the radio works fine so not a power issue, i have an identical unit in my Clio which is not being used at the moment but when fitted in the Citroen it does not work. I've seen on ebay units for sale with codes if the vin is supplied, is there any way I can do this at home to save me buying a new CD player. Thanks in advance
Radio codes
Moderator: GiveMeABreak
- x 5806
Re: Radio codes
Are you talking about the single slot CD in the head unit, typically an RD4? Or are you talking about a CD changer unit?
These units are coded to the vehicle using the VIN number. This is nothing you can do at home unless you have your own Lexia diagnostic tool to code it to the vehicle.
Also be aware, that although the unit may look similar they may be entirely different internally between Renault and Citroën . They have to be the same units using the same electrical architecture with the relevant software and hardware version to be compatible with PSA vehicles.
Post up your VIN here and I’ll advise you of the correct part number for a compatible replacement,
Re: Radio codes
Hi Marc Thanks for your reply, the unit is a single slot cd/radio. I have been on ebay today and there are loads of units for sale at reasonable cost so was thinking could I install a new system which would include being able to access music from my phone or will I have the same problem getting it to work properly.
- x 5806
Re: Radio codes
It is important that I understand what Berlingo and equipment you have - so your VIN is important.
Secondly, be aware that if replacing the unit (if you have an RD4) with a non-RD4 compatible unit - it will block certain configuration of your vehicle unless you are replacing it with a like for like unit - which will still need to be VIN coded to your vehicle - they are NOT plug and play. The Head units in PSA vehicles interface with the vehicle's main computer system to activate and deactivate certain functions. Putting a non-PSA unit in will mean losing some of the ability to change options.
Re: Radio codes
Thanks Marc
The vehicle VIN is VF7**************[VIN obfuscated, can be read by forum staff]. Its obviously not a case of just buying a replacement unit and slotting it in like the good ole days.
Ive seen plenty of used units on ebay for about £30 to £40 and new boxed Kenwoods for around £50 but I will wait before I buy anything.
Thanks again, Steve
Thanks again, Steve
- Donor 2023
- x 3012
Re: Radio codes
There are forum members who have Diagbox clones, and are willing to help out others. Here is the list/map;
viewtopic.php?f=19&t=56452
So if you get a PSA system that is compatible with your vehicle they should be able to 'tell' it about the change of radio, so that it doesn't BEEP at you every few seconds!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- x 5806
Re: Radio codes
Ok so on your 2004 model, you have an RD3, a precursor to the RD4. You also have the slightly older multifunction screen.
So the current RD3 unit is controlled by the ECU in the multifunction screen, which authorises the power on and off of the unit and the supplies.
So if you want to fit an aftermarket radio in, you will need to get a special harness to interface with the vehicle and possibly to maintain the steering wheel remote controls for the volume and station / track search etc.
I don't think a later system like the RD4 will work without changing the multifunction screen and programming it in. It might be a bit too new for your vehicle.
If you want a non PSA unit, you'll need to search for an electrical adaptor harness to interface with and RD3 system.
