Change language RT3
Moderator: GiveMeABreak
- x 5863
Re: Change language RT3
Hello to all
I am an new owner Peugeot 1007, from 2005, petrol 1,6L.
I have an RT3-vanbus I also need the configuration CD to change language to english. Please help a fellow peugeot owner. Bonjour à tous
Je suis nouveau propriétaire Peugeot 1007, de 2005, essence 1,6L. J'ai un vanbus RT3.
J'ai également besoin du CD de configuration pour changer la langue en anglais. S'il vous plaît, aidez un autre propriétaire de Peugeot.
- x 5863
Hi,
I also need a config CD for an '06 Peugeot 807, recently acquired from Switzerland. The media is now in German, if that matters, and I believe that it's the RT3 with navigation and telematics.
Thanks in advance.
Thanks in advance.
- x 5863
You'll ned to post the VIN up as there are 2 systems and the software is not interchangeable.
Sure VF3**************[VIN obfuscated, can be read by forum staff]
- x 5863
Ok, so check your private messages.
Hello,
Just bought C2 VTS from 2005
VIN VF7**************[VIN obfuscated, can be read by forum staff]......
soft version: 5.52.A-2
Have original CD, but not working, maybe because its a 5.5D version
Thank you
Thank you
- x 5863
There are VAN and CAN systems which are not interchangeable. You must use the correct software for the correct version or you risk bricking your unit.
If you don't know which system you have, please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Hello Marc,
Its a VAN. Which is the latest firmware?
I found 5.52 and its ok. Is this one the latest?
Thank you
Thank you
- x 5863
Yes 5.52 is the latest for VAN Bus Systems. Just select language from main RT3 Menu, and insert CD when asked for, follow instructions and system will restart and you should have the preferred language. Eject CD.
Thank you Marc. My GPS is not working, no satelites found. Do you maybe know where is the GPS module in the car? Is it on the windshield?
- x 5863
You will have to determine where the fault is.
1) If you have updates the software first go for a drive of over 10 minutes. This is to allow the GPS to lock onto the satellites and this cannot be done when the vehicle is stationary.
2) If there are still no visible satellites, you should next buy a cheap GPS antenna with suitable fakra connector from ebay or somewhere and plug this into the back of the RT3 and leave the receiver on the dash fastened down with some tape. Then repeat the 10 minutes drive and see if the system then picks up any satellites. If it does - you know the issue is with the antenna.
3) If this still produces no satellites, then the fault is likely to be internal with the GPS tuner. When mine went, it would mean the unit being sent off to Clarion for repair, but I was already in the process of selling my C5 when this happened to me, so never got it fixed as they wanted about £400 for a repair!
The GPS tuner is internal to the RT3. The GPS Aerial is routed to the roof antenna along with the GSM and other aerials.
- x 5863
@tecnomar: Check your Private Messages
