I find it very distracting at night, I have lowered the illumination to the lowest level but it still bother's me. Can't find anything in the handbook - unless I have missed it, par for the course.
C5 X7 satnav display - can you turn it off?
Moderator: GiveMeABreak
- x 1210
Reason: Moved to the RT4 Telematics Section
- Donor 2023
- x 1393
Re: C5 X7 satnav display - can you turn it off?
Unless you're actually using the maps why not put the radio screen up? Repeated presses of the button at the end of the RH stalk (wiper) will cycle through the three options.
- Donor 2023
- x 3012
I wonder if you have the ability (within the SatNav software) to get it to switch between a day and night display. On mine (which is an app on a mobile phone) it will have the background in white during the day, and black at night.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- x 5849
You have the RT4 system, but I can't recall this having a night / day mode for the map display which the later models did, but either way, put your illumination back to the levels you want and activate the Black Panel function.
Press Button (10) on the diagram (at night time or you won't see anything). There are several modes - just cycle through them. First press will cut the dash lighting and instruments and if memory serves pressing again cuts lights to everything except the speedo - but if you press on a control anywhere on the steering wheel (say volume or station search), it temporarily illuminates the Telematics unit again, then reverts back to the previous mode. Pressing again returns full dash lighting. I know on my later Navidrive, that if navigation is active, and I have the Black Panel active, the coloured dot matrix display on the instrument panel will illuminate with the next road turn.
- x 120
The RT4 does have a dark button on the left directional pad on the front of the unit. A bit hard to press when driving though!
- x 5849
Thanks for confirming that Elis. With all these options you should have it covered now Peter.
- x 1210
Thanks once again Marc and ED and Paul. I don't think I could run these cars without your help. Never noticed that button or did and didn't know what it was for - like many others.
