MyWay Radio Phone Help
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
Moderator: GiveMeABreak
cantavoidcitroen
Post by cantavoidcitroen »
As of today I am now an owner of a 2010 Citroen C5 2.0 HDI VTR+ (Nav) and I am trying to get to grips with the MyWay head unit and have come across an issue regarding the address book. I am able to receive calls and dial a number but can't use the address book menu to call any numbers that I have saved on my phone. I have also tried to create a new contact via the phone menu but when it comes to save I am presented with a "Please Wait" screen that doesn't seem to disappear, unless I press "List" on the steering wheel and of course the number doesn't save.
The phone that I am using is a Samsung Galaxy S7 if this any help?
Hopefully someone will be able to give me some advice :)
x 5806
Re: MyWay Radio Phone Help
Post by GiveMeABreak »
Hi and welcome.
The MyWay unit has no hard drive in the system and relies on flash memory. When a new phone is paired it can take a significant amount of time (and the car needs to be running) for the address details to synchronise. If the car is switched off the connection is terminated unless on a call, so will interrupt the process.
cantavoidcitroen
Hi there,
Thanks for the reply. Everything that I was trying was done with only the ignition on. I'll have another look tomorrow, hopefully with desired results. Really appreciate the helpful info :)
admiral51
Donor 2023
x 378
Post by admiral51 »
As the OP is my son i will now update this thread as the main issue has been resolved :)
Thanks to Marc i now have the updates for the firmware for the head unit but being non tech savvy i have yet to get the update to work but back top the issue.
In frustration of not getting the system to accept the SD card with the update on i decided to get the head unit to do a factory reset with the engine running.
Once that was done the unit now behaves itself, within seconds of pairing a phone it allows access to the phone book of the phone as it should do.
It has been tested on 2 phones and works with both so =D>
Still going to keep trying the firmware update when i finally understand the technical process :rofl2:
x 5806
Just use a free programme like 7Zip to extract the files onto a FAT32 formatted SD card from your PC. Don’t actually leave the firmware archive itself on the SD card though, just the extracted files.
Switch vehicle off, wait 5 minutes to allow the Head Unit to sleep, and insert the SD card, then start the engine and it should start the firmware upgrade process - but NEVER interrupt the process or you risk bricking the unit.
Donor 2023
x 1389
Post by Paul-R »
Just a thought about computers. For updating the maps on my C5 I have to use a Windows machine as a Mac infects every writable device with a load of invisible files and folders (don't know about Linux machines). These invisible files interfere with the process.
Possibly the same for this update?
"Trying is the first step towards failure" ~ Homer J Simpson​
admiral51
Donor 2023
x 378
Post by admiral51 »
Marc i do have the correct info only on the SD card, checked with your sticky and exactly the same so got that bit right :)
Bad news is i moved the car into the driveway, switched it off and inserted SD and then started it up, thing i did not do was wait for it to go back to sleep for 5 mins so will try it again this weekend doing it the correct way.
Paul anything is possible with me and tech, but i think on this one i may have done it 50% correct lol
