Just jotted some thoughts on the above problem, may be of some help.
BX Head Gasket Failure Checks
G4EIY
Hi All,
Brian - 86 Visa 17D Sorn(192K)/ 86 BX 17RD (220K) Scrapped/ 92 BX 17TZD Turbo Diesel (191K)
96 306 XRDT (174K)
96 306 XRDT (174K)
tomsheppard
There is one rock solid Is it, or isn't it test for a failed headgasket.
With the engine stone cold, start the engine and idle it for 45 seconds before switching off. Now remove the coolant filler cap. If water emerges under pressure, the head gasket has failed. If not, 99.9% certainty that it hasn't.
Be happy: it is a way of being wise. (Confucius.)
'92 TZD Estate(Grolliffe), Gone but never to be forgotten.
'95 405 GLX TD Estate. too new to name.
