xantia heater illumination
When driving at night with lights on my heater controls are backlit except the temp bar and fan speed. This is very annoying,[:(!] should they be lit if so is it difficult to get in at bulbs[?]
Yes they should be backlit.
Dont ask me why but Citroen Dash bulbs last mere nano seconds, whereas all other makes seem to last forever. Both my citroens have missing dash lights.
Have a search on the forum as there was a thread not so long ago about changing the clock back light, and that gave info on how to remove the dash to do ALL the bulbs (change em all in one go, if you can see if you can get white LED bulbs instead).
You need to remove the radio surround by way of removing the two screws located at the bottom of the panel from where the ashtray pulls out. The heater panel then unscrews, you will also need to remove the radio in order to gain access to remove the top cover on the heater panel. Its then a case of jiggling the bulb holder out.
The bulbs are not the usual capless type, they come complete with the black plastic bulb holder.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
If you go the LED route you can get them here..... http://www.ultraleds.co.uk/
I did a LED conversion on my dads ZX, I used whitle leds and soldered them in place. I think I probably go for green LEDs if I had to do it again, as the white ones made the dial print more of a 'minty' green.
All my ZX bulbs, touch wood, *touches head* are working, but when the time comes, and it will, it'll be LEDs over bulbs
- uhn113x
- My Cars: 1981 Dyane - on road all year round.
1982 GSA Pallas - on road April - September.
1997 ZX 1.9D Dimension. - x 1
It will, but not as well, as the LEDs only use a fraction of the current that bulbs do. You may need an extra bit of electronics to make it work properly.
WCN Supplies are selling green 5mm LEDs 25 for 50p at the moment!!
Details on http://www.ukmodelshops.co.uk/counties/ ... onics.html
- uhn113x
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zorgman</i>
You cant just plonk LEDs into place where the bulbs are as LEDs work on approx 1.2-3v depending on the type so you need a resistor in series with the led to drop the voltage. This can be done at the lights feed going to the dash on one of the multi connectors
Quite right, but it is the <b>current</b>, not the voltage, that is important. What you should <b>not</b> do is connect LEDs in parallel like the bulbs are connected, with just a single resistor as the forward voltage drops do vary, and you risk overrunning one or more of them, shortening their life.
Assuming your LEDs take 20ma (0.02 amp) and drop 2.5v, then, taking your max battery voltage as 14.5, you need to drop 12 volts at 20ma = 600 ohms - nearest preferred value 560 ohms - resistor in series with each LED. You can also connect, say, four LEDs in series, with a lower value resistor.
Lee
There are indeed '12 volt' LEDs available which have an inbuilt resistor, but not all of these will stand much more than 12 volts, and they are more expensive.
Lee
- uhn113x
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PowerLee</i>
12 Volt LEDs from Maplins are less then 30 pence each.
S'right, but have you looked at the ratings? Vf max = 14 volts. Assuming that your alternator is reasonably within tolerance, the output voltage is normally above this, and can rise to about 14.8. Ok, it will not blow the LEDs instantly, but will shorten their life, and one of the reasons for converting from bulbs is that you will never need to replace them.
I know its a bit off topic but I have always found the Gsf dash bulbs to work longer than the hal%$ds rubbish, In fact I have'nt had to touch them after replacing, Other rubbish ones in same unit work sometimes not others then give up the ghost after 6 months, First thought it was contact problem but after refixing with Gsf units its fine.
One other thing to check when fitting led's, is the polarity.
I have fitted white/blue superbrights to my BX (using 560ohm resistors),to the internal, rear number plate and side repeaters, the centre connection on the repeaters was negative.
This had me foxed for a while, as I had assumed all the centre lamp connections would be positive.
Cheers
Cheers
