Apologies in advance for long drawn out explanation but this problem is driving me crazy.
1)Start engine from cold and after a few seconds STOP and temperature warning lights start flahing.
2)Once engine reaches normal running temperature cooling fan cuts in and STOP and temperature warning lights go out, (LH fan only operating), as soon as fan stops lights start flashing again.
3)All the above happens when interior heater fan is switched on in any position. Switch the interior heater fan off and STOP and temperature warning lights go off, but then engine cooling fan(s) don't work at all.
I have looked at the various wiring diagrams in Haynes manual for HDi (post 98 cars) which shows seperate diagrams for engine cooling,heater blower & air con.
So far I have replaced cooling fan relays to no avail, checked cooling fans (both are ok)
HELP!!!!!!!
HDi Cooling Fans (2000 MY Xantia)
