The sump plug on my current Xantia has a socket in it but it also has a hex head that a normal socket will go on if you know what I mean. I round either set of flats off, I've got another set as a backup.
Perhaps you could get a sump plug like mine.
Butchered Sump Plug
Just read through Haynes BOL about 2.5TD sump removal - funny while under the car it didn't look too difficult - according to Haynes its an auxilliary belt and bottom engine mount off job - darn, specially as the gasket appears to be weaping, I thought I'd kill two birds . . .
Must get under it again and see if its really true . .
//NiSk
//NiSk
Well the MIG and a suitably ground-down 12mm bolt did the trick - I'd guess that the heat from the welding did most good. Plug now replaced with Citroën original (and rubber-faced washer - which was sadly lacking from the stuck drain plug!) with square 8mm hole in middle.
Pumped out the old LHM while I was at it - nasty dirty yellow-brown colour and the filters were completely black (couldn't even see through them!). The LHM tank wash-out will have to wait until I drain out the Hydraflush the system is now circulating in 5000 km, The XM 2.5TD really is in the same class as the Jag XJ12 when it comes to space in the engine room - looks like I'll have to dismantle half the induction system just to get the LHM tank out (including the air/water intercooler!)
//NiSk
//NiSk
