Becoming classics?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I dont understand why the standard bx 16v had so much silencing<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Nor do I, which made me wonder why he spent all that money on a carb conversion, intake work, etc, only to replicate the standard exhaust system.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">he's been seduced by a Swede... and no it's not Ulrika<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Its not Sven, is it??????[:0][:0]
Anyone intrested should take a look here and read the wise words of Dave Baker http://www.pumaracing.co.uk/pug16v.htm If you have not seen it before, its generally accepted as "the" tuning guide for the 1.9 16v.
- Contact:
Are we all missing something here, though? If that 168 BHP is at the wheels, then it is a respectable output.
Trouble is, no matter how much you sspend on making it go faster, there will be something that does the job better and cheaper. The BX has the advantage of power to weight ratio, being made of coloured air but the money spent to get it to go, compared to a Saab which already does, makes the BX solution irrelevant.
People are not going to pay Ferrari money for a BX.
As for the "If it is not original, it is not classic" argument, There isn't one.
There was an old Ecurie Belge D-type at goodwood last year that had been hacked around with brackets and heaven knows what rivetted all over. Against the pristine "original" car, this was far the more valuable. Remus isn't original either but He'll be the least affordable ERA. A continuous competition history helps.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by VisaGTi16v</i>
Re: bx 16v exhausts. The standard system has about 8 foot of silencing in total across the 3 boxes as one goes in and back out on itself. Ive now got a 1.9 16v in my visa and that just has a single pipe to 1 rear silencer thats a bit bigger than standard with a 2.5-3 inch exit pipe and yet the noise isnt too loud. Well inside the noise regs for me and passes mot emmisions fine so I dont understand why the standard bx 16v had so much silencing
The first 'silencer' is not a silencer but a tuning part. Its an expansion chamber which is used to absorb the pressure waves produced by the exhaust valves opening and releasing the high pressure inside the cylinder. The wave travels at the speed of sound (which for the hot exhaust gasses is not the same as in cold air) and then is stopped or reflected at the expansion chamber. The greatest affect occurs where the seperation piece inside the exhaust finishes and this sends low pressure down to the other exhaust valves for scavenging. The remaining energy of the pressure wave is absorbed by the expansion chamber so that it is not reflected by another part of the pipe which might mess up the original tuning of the pipe.
You might not lose lots of power removing this part but its not there for nothing. This is similar to what I was saying about the inlet manifold.
Remember Citroen knows best!
- Contact:
- Contact:
- Contact:
Does the 8v have the same manifold? Weird on the 16v having 8 exhaust ports into 4 then into 2 and in the first foot or so of the exhaust is a divide in the middle which im told is to equalise the lengths of the inlet/exhaust manifold area or something, donno where I read that
http://home.iprimus.com.au/bwjones/neil/001.jpg
There are a number of theories that apply to exhausts but one is to try and equalise the pipe lengths and split the pipes until the first junction. So with a firing order of 1342 nos 1 and 4 are joined as are 2 and 3. This means that an adjacent pulse goes into the other pipe. The 16 valve manifold seems to be built on this basis, subject to the restrictions of front wheel drive and transverse mounting.
As for the sharing of exhausts components with the TD and 8 valve - having designed one free flowing exhaust why bother to design others. The TD will not have problems with pulses as the turbo will break them up nicely but will of course need to pass a high volume.
jeremy
jeremy
jeremy
jeremy
- Contact:
Theres another bx on ebay now but this ones far from standard. I dont know whats worse, the steering wheel, bonnet vent, headlights or the rear seat belt pads!!! ARGH http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... eName=WDVW
