Hi All.
Car: Xantia 1.9td 'L' reg
Problem: Height corrector bracket on the anti-roll bar broken.
Solution:Replaced the bracket
Question: How do you set the correct ride height?
After replacing the bracket and connecting the 'plastic' link, the ride height is too high at the rear. I've tried adjusting it by raising the vehicle and supporting it with axle stands, moving the bracket slightly, lowering the car and testing it out, then repeating this procedure.[:o)]
There must be an easier way.[;)]
Does anyone know the correct (simple!) procedure for setting the bracket to the anti-roll bar?.
Cheers,
Alucard
________________________
ps.
I have new spheres and height corrector. Its the bracket that's causing the height problem.
pps.
I have some images of the area, which may be of interest to other members as this seems to be a common problem. If someone lets me know how to upload them to the forum, I will.
Xantia - rear height adjuster bracket problem.
Robin
Hi, you are on the right track really. Moving the clamp bracket on the main 'tube' that goes across the car is the means of adjustment. All I can say is that a very little goes a long way! I cannot recall now which way to move the bracket for up or down. Suggest you put the car on ramps, very securely and move the bracket with the engine running to gain the correct height. It is detailed here on the forum somewhere so just do a search, top right corner to read the links.
A word of caution though. To rise or lower the car must be able to rotate the rear wheels so if the handbrake is on or the front wheels chocked the rear wheels must be free to move. Please take great care when working underneath on a live suspension. Robin
Robin
look at this link for info.
http://www.andyspares.com/discussionfor ... adjustment
Alucard
Thanks for your time and the info, Robin.
I checked the link you gave and it is all becoming clearer.[:)]
It's my first dealings with this system and to say I'm confused, is an understatement.
I'll be undertaking the task within the next 2 days and will post my findings on the forum, as I'm sure others will come across the problem!
Thanks again m8,
Gordon (Alucard)
Thanks again m8,
Gordon (Alucard)
Alucard
Dave Burns
Alucard
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Alucard</i>
I should have said "The next 2 nights!"[:D]
Well spotted Dave.[:)]
