Xantia 2.0
Lynn
Xantia 2.0
Unread post by Lynn »
Hi,I own a Citroen Xantia 2.0 SX and a while ago it started to be a bit bouncy at the rear,I recently had the spheres replaced but it seems to be the same,also had 2 height correctors fitted,anyone know what can be causing this bouncing,I would appreciate some helpful advice,thnx
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
With the engine running, raise and lower the suspension fully a few times. It might just help.
xantiav6
x 3
Unread post by xantiav6 »
Check that the ride height is approximately half way between the highest and lowest postions. The suspension does not work very well if it is sitting near the top or bottom of its range.
jeremy
Unread post by jeremy »
is this the dreaded plastic link problem? Does this link help?
http://www.andyspares.com/discussionfor ... IC_ID=8745
jeremy
