Additive Level Reset - No response from ECU
Martins2759
Unread post by Martins2759 »
Hello everyone,
I'm having trouble resetting the Additive Level counter. When I do a full test, unlike other examples I see on here, I do not see a dedicated Additive Pump ECU. I can, however, via the Engine ECU, get to a menu where I see a "Diesel fuel additive control unit", which gives me options to reset the counter. When I try this, the ECU never responds.
Car: Peugeot 206 CC 1.6 HDi
MOC: 11014
Diagbox versions I've tried: 7.58 and 9.68
I select "206MUX" as I believe that is the right option given my MOC code, and have tried the plain "206" option, but still with no luck getting a response from the ECU.
What else should I try?
Could I be looking at a bad fuel additive control unit? If so, where would it be located?
Thanks in advance!
