C3 A51 Air Con Compressor not turning
abyj
Re: C3 A51 Air Con Compressor not turning
Unread post by abyj »
Got it - So the likely scenario of what happened is that the coil in the compressor clutch failed taking out the BSM, which as a result is now not sending the correct signals on to the compressor. So in theory if I replace the BSM and the compressor clutch the AC should be back in business. Any complications replacing the BSM? - just simple plug the new one in and it should work? i.e. no programming or gotchas?
ozvtr
x 173
Unread post by ozvtr »
There is no "coding" required for the BSM.
I am not too sure about the current crop of BSM's. There were multiple versions of the original BSM's BUT later ones appear to all be the same. The diesel versions may have extra circuits for heaters and what-not.
