I have just been offered a Citroen estate 1.9td 96 N.
There are a couple of problems clutch and timing belt but the one that concerns me the most is that the dorser valve needs changing.
The symptoms are very aggressive braking with no feel on the peddle.
It has been diagnosed as the dorser or dump valve (on the bulk head) by citroen mechanics.
<b>Is it a difficult job to change? </b>
I have access to a spare valve from a donor vehicle.
Your help would be appreciated.
Dorser or dump valve
AndersDK
I presume you mean a Xantia ??
Then it's the brake master (pedal) valve we talk here - in Citroen world designated the "doseur" valve, which in french simply means a "dose" valve, to adjust the flow (dose) of hydraulic pressure out to the brakes.
Because this valve is located low down on the bulkhead in the engine bay, right behind the engine, it's a pig of a job to access and replace the pipeworks fitted to the valve.
Normal procedure is to remove the fixing bolts (nuts ?) from inside footwell, then simply carefully pull down valve for easy access of the piping. Piping is delicate, easy to kink, and pipe unions may have rust seized in pipe ports, making it a nerve stressing job.
No wonder it's quite a beefy job on a garage bill.
ItDontGo
If there is air in the brakes they suddenly come on really sharply after a slight delay. The pedal will not feel spongey like on a normal car with air in the brakes either. Most neglected cars seem to benefit from a good 'Citrobics' workout followed by a brake bleed.
The brakes on a Citroen feel weird even when they are new!
caeclyd
Thanks for your response.
" the brakes they suddenly come on really sharply after a slight delay" that is exactly what happens.
Anders that is the component I am talking about it is in a pig of a location. Do you know if there are any special tools required?
Idontgo you suggest a Citrobic work out ? followed by a brake bleed.
Does this mean work the hydraulics up and down a few times ( with plenty of lhm in the system) ?
caeclyd
ItDontGo
AndersDK
caeclyd
Anders,
No it did not work.
As I already own a Xantia it was to be a replacement BUT to an enthusiast
http://www.andyspares.com/discussionfor ... IC_ID=8472
No it did not work.
