Hi All, im in the middle of changing my head gasket and have got everything off apart from the head itself, ie. Timing belt, Auxillery Belt. Just before removin the head i had to remove the Exhaust manifold which is fine but the only problem is the studs that are attached to the head have to come out as well before it can be lifted how the hell do i get these studs out??
Jazz
Help Please and Quick
If you mean that in the process of screwing the nuts off the manifold, the actual studs that they screw onto also came out, what's the problem? Just screw them back in like they were bolts.
If you want to get the nuts off the studs, then soak the lot in kerosene overnight and as has been suggested, hold them in mole grips or a vice and then unscrew them or alternatively, heat them with a blowtorch and then get the nuts off that way.
Alan S
Alan S
