Help please! Attempting to troubleshoot 2001 Berlingo Multispace 1.9d starting issues
Rhothgar
Donor 2023
x 122
Re: Help please! Attempting to troubleshoot 2001 Berlingo Multispace 1.9d starting issues
Unread post by Rhothgar »
wheeler wrote: 06 Oct 2024, 12:13 Thats not really the same thing as a volt drop test but yes there is an acceptable limit for this.
Firstly i wouldn’t use a voltage display on a diag tool, there is too much of a delay, use a proper voltmeter connected directly to the battery.
A good battery should not go below 9v on cranking.
An old way of testing a battery would be to disable the engine from starting (removing the fuel pump fuse for example) then crank the engine for 10 seconds. A good quality meter will have a max/min record function, set it to record minimum & it should not go below 9v with 10 seconds of cranking.
I didn't think it was but wasn't sure hence asking.
Fully agreed about resolution on diag tools (unless picoscope :-D )
So that is interesting because it drops to 9.5 or 9.7V but is REALLY sluggish turning over.
If I did disconnect fuel and crank, it wouldn't be anywhere near that voltage after 10 seconds. It would probably just grind to a halt!!!
Thanks for the advice. Have a great Sunday.
x 5163
These any help?
Rhothgar
Donor 2023
x 122
myglaren wrote: 06 Oct 2024, 13:07 These any help?
Thanks Steve. Very much so.
