2001 206gti dash lighting inop
x 6055
Re: 2001 206gti dash lighting inop
Post by GiveMeABreak »
We don't supply mass schematics here.
We may supply the odd one or two for a specific issue if we have them.
cooknl
Post by cooknl »
wheeler wrote: 04 Jul 2024, 11:34
cooknl wrote: 04 Jul 2024, 11:27
I am not sure what you mean with
""check it for a sidelight feed""
I mean check that this terminal goes live with 12v when the lights are switched on.
OK thanx that clarifies it.
Rob
cooknl
Post by cooknl »
GiveMeABreak wrote: 04 Jul 2024, 11:35 We don't supply mass schematics here.
OK I understand that.
Can you help me with a link or other way to obtain the non muxed 206 schematics?
x 6055
Have a look here:
https://haynes.com/en-gb/car-manuals-1
Use the manufacturer logo and follow through to the model and year. These are digital and contain some wiring diagrams.
cooknl
Post by cooknl »
GiveMeABreak wrote: 04 Jul 2024, 11:49 Have a look here:
Tried that but nothing pre 2002m thx for the headsup though, the car is a 2001 .
PS update on the problem no lighting in the instrument panel, after some more checking we found that the taillights the parking lights and the horn were not working either.
After checking a users manual from a friend we found that fuse 5 in the engine compartment fuse box was defective, so replaced fuse 5 and voila all works as new.
Thx all for all youre helping hints and efforts.
Rob
x 6055
Thanks for the update. If you'd mentioned the other issues, that's probably the first thing I would of suggested being they are all on a common fuse - but at least you've sorted it now. :wink:
cooknl
Post by cooknl »
Hoi Marc,
Yes problem was i wasnt told either and the reason the fuse blew former owner had an amp in the trunk which he pulled out when he sold the car but left the wire ing in and that caused that the plus that he pulled from the taillights to power the amp was left in the trunk and that caused the short on fuse 5. so i cut that wire out so no more shorts , what a situation heh lol.
Rob
