Never criticize your Citroen
x 7083
Re: Never criticize your Citroen
Stickyfinger wrote: 18 Jun 2024, 09:29 Not the same as the image you have posted.....
Yes sorry Alisdair should have read the Bronco thread fully. A few pages in the poster revealed it as a joke... edited out now!
As revealed at the bottom of the image<br />(This actually from an Audi)
darbuck
x 240
Unread post by darbuck »
That looks like it would be great craic to work on. Sarcasm intended
Darren
x 7083
Using a far more reliable source of evidence than internet opinion, pictures of second hand engines for sale on pallets from salvage yards, and not having found an Audi/VW engine to be a good match, I think that this is the most likely engine in the picture...
A BMW N63B44A V8 Twin Turbo.
The N63/S63/S68 has the characteristic turbo's inside the V, and also those characteristic grey/silver Metal "pots" leading up to the turbo's either side of the V. The example in the table shows a decent match for those pots, later versions of the engine, the "pots" are slightly different.
Spoiler: show
e-bay sale item ref https://www.ebay.co.uk/itm/296361633702 ... gJCFfD_BwE
for enlargement of image purposes only
x 1703
Unread post by MattBLancs »
The grey pots are air to water heat exchangers (sometimes called a charge cooler) I believe (rather than conventional air to air heat exchangers i.e. intercoolers)
Let's you keep boost pipework length / volume low but needs coolant lines, an additional radiator (separate system to the engine cooling system radiator) and circulation pumps to shove the coolant round.
x 7083
MattBLancs wrote: 18 Jun 2024, 20:53 The grey pots are air to water heat exchangers (sometimes called a charge cooler) I believe (rather than conventional air to air heat exchangers i.e. intercoolers)
Thanks Matt, excellent additionals there, didnt know what to call them :-D
x 1703
I've got a new one in a box (to fit a Renault / Nissan, rather than this Audi / BMW engine in the pictures) - I had a mad idea to add it to my 2.0 HDi 306 (which has no intercooling as standard) when i stumbled across it (irresistibly cheap, new in the box, from memory something like £20!) on eBay a good few years back.
Still sat in the box (and the 306 is sat waiting a considerable amount of welding or a trip to the big scrapyard in the sky) so I can offer you a picture come the weekend if desired! :)
x 1703
Wondering if that engine has one of these onboard too:
Example picture from Google, think these are Renault items
Spoiler: show
a water cooled alternator!
Sometimes used by VW, BMW and strangely Renault (I looked into one a bit ago after hearing mention of it somewhere. Yes, because I really am sad like that! :hole:
x 7083
MattBLancs wrote: 18 Jun 2024, 23:10 Still sat in the box (and the 306 is sat waiting a considerable amount of welding or a trip to the big scrapyard in the sky) so I can offer you a picture come the weekend if desired! :)
Shove it on POTD Matt. I did try to inspire a bit of incongruous objects photography. Take a shot of the Heat exchanger/charge cooler against a background of something incongrous, like my track rod end on a bag of cement here...
viewtopic.php?p=763575&hilit=incongruous#p763575
Or Flex Brake Hose Clips and Puffins here
viewtopic.php?p=763027&hilit=incongruous#p763027
