Peugeot ECG Can't change gear - P0868 - oil deficit fault
x 880
Re: Peugeot ECG Can't change gear - P0868 - oil deficit fault
Post by xantia_v6 »
I would question the correctness of the Comma data sheet that implies that AQ3 is compatible with both Dextron and 9979A4.
x 6054
Post by GiveMeABreak »
vmguru wrote: 13 Jun 2024, 21:38
Thanks that's seems very expensive for 1L of oil, will have a look around see if I can find it at more reasonable price, the specification from what I can see is "9979A4"
same stuff but cheaper https://www.ebay.co.uk/itm/324989317747
No, that is not the specification, that is the part number for the official oil.
The system needs special oil - you can't put any old oil in unless you want further problems, it is a special hydraulic oil not a gearbox oil!
vmguru
Post by vmguru »
xantia_v6 wrote: 14 Jun 2024, 07:20 I would question the correctness of the Comma data sheet that implies that AQ3 is compatible with both Dextron and 9979A4.
I called Comma today to double check about the actuator oil they said this is correct the AQ3 is the required product and equitant to 9979A4.
https://www.commaoil.com/ (can check up required oils with car reg)
x 6054
As long as it is equivalent to Tutela CS
vmguru
Post by vmguru »
Today I managed to fill the actuator reservoir with oil the car went into gears and then stopped changing gears again noticed the reservoir empty, looks like I have a major leak somewhere. I will be towing this to the garage tomorrow for them to take a look once fixed going to get rid of this car never buying a ECG gearbox car again!
x 6054
Best to get a proper automatic with torque converter or stick with a manual.
x 1061
Post by RichardW »
There's a high pressure pipe which wears / corrodes through, or the slave has burst in the bell housing. Surprised you cannot see oil everywhere!
