Xantia 1.9TD....wake up and back on the road after 10 Years
Huskyxantia
x 519
Re: Xantia 1.9TD....wake up and back on the road after 10 Years
Unread post by Huskyxantia »
Wonderful news abiut the car passing its test , im steering clear from places that use shaker decks as this machine busted 2 springs last yr on my 308cc , so went to an old fashioned place where its all pitt work . When locals started talking about the usual place i used for a good few yrs and hearing about springs being broken by the shaker deck that was it for me .
Just hope no one else has had this happen to them on here.
Congrats once more its nice to see a great old car saved .
:-D
x 980
Unread post by xantia_v6 »
No problems with the shakers for my Xantia or XM.
x 6999
I'd worry about either of my AXs on a shaker... I'd be worried it might fling the poor little car right off the deck and up into the roof of the MoT bay :roll: :lol:
xantia_v6 wrote: 23 Nov 2024, 22:29 No problems with the shakers for my Xantia or XM.
I'd imagine it might reveal borderline strut tops Mike; in the worst possible way!
Huskyxantia wrote: 23 Nov 2024, 21:59 im steering clear from places that use shaker decks as this machine busted 2 springs last yr on my 308cc , so went to an old fashioned place where its all pitt work .
Mine still does it in the traditional way Husky, After all, it's easy to shake an AX... Just hold it in your hand and shake it like a rattle :lol:
So, what's the comeback if the MoT tester breaks a spring or causes other damage whilst using the shaker? Are they bound to make good?
x 6603
Shakers are for Martinis, crowbars for MOTs !! :-D
x 1718
Unread post by MattBLancs »
CitroJim wrote: 24 Nov 2024, 06:24 So, what's the comeback if the MoT tester breaks a spring or causes other damage whilst using the shaker? Are they bound to make good?
Ha ha! Fat chance I'd say!
There's normally some sort of disclaimer about cam belt snapping on the diesel rev up test being not the MOT tester's fault (though I think there is also a route for them to refuse to do that test - not in fit condition or similar (will dig it out) - I'd think "not our fault it snapped a spring on our shakey thing" was similarly disclaimer-ed off their conscience! :oops:
x 1610
Unread post by Stickyfinger »
Very good service from Advanced Paints.
They decided after two attempts to issue a refund......fair play, no arguments at all.
x 6603
I don't know if you have found an alternative Alasdair but this is the company I have been using for the last 5+ years and I've always had a good match:
https://www.ebay.co.uk/itm/302315456624 ... 1152398844
x 1610
I HAD to remove the large /thick steering wheel cover as I do not like the increased thickness that the "stretch-over" type offer....and they look horrid....and I needed to clean the wheel etc.
So off to the Amazon to access a cheap China cover that is leather (lol, very thin) and stitch on...........eerrr, this takes a LOT longer than the small handed speed stitcher on the "how-to stitch" videos on youtube !!!!
Huskyxantia
x 519
Thats very impressive looking , That Dash shine is outstanding.
Answer to Jim regarding my broken spring shaker deck issue,
They wriggled out of it, you can tell if you have a broken spring ,even more so having two, as i recall i cleaned all the brakes a day before the mot so they were all doing what they were made to do even checking springs to nothing broken as far as i saw, one spring that was broken due to this mot was a replaced one which i did not long after i got the car , you knew that was broken as it rattled and clattered over speed humps and rough road surfaces. So now use this place https://maps.app.goo.gl/onkHmA6aypG5MM5Z7
:-D
x 1610
Why would a shaker deck make a spring fail faster than a road ?......if it fails on the shaker would it not have failed soon on the road ?
x 6999
That new steering wheel cover is starting to look good Alasdair, a vast improvement on the previous one although in one way I liked it as I do like 'chunky' steering wheels and not too keen on thin ones. My AX ones are borderline too thin for me... Polly my Picasso has a 'just right' one :)
Husky, noted on the spring breakages...
Huskyxantia
x 519
Stickyfinger wrote: 30 Nov 2024, 12:08 Why would a shaker deck make a spring fail faster than a road ?......if it fails on the shaker would it not have failed soon on the road ?
I was watching , it was rockin more than Elvis ! The lad walked off to make a coffee but soon ran back to it when i asked wtf was happening.
:-D
x 1610
it was rockin more than Elvis .....but cars "rock more than AC DC" on the road.....still do not understand the dangers of a shaker bed TBH.
x 6603
Only theorising here as I've never seen the shaker bed. If they 'vibrate' similar to paint mixers then I wonder if the problem is something to do with them hitting a resonant frequency of the spring's material? Just a thought! :-D
More info on material failures as a result can be found at: https://www.omnicalculator.com/physics/ ... xplanation
Huskyxantia
x 519
Its as easy as , before my springs were fine , after this mot, 2 were broken & to many way to many flimsy reasons why there machine didnt do it , 3 local people i know have had damage by the same place over the last 2 yrs there miss use of this pile of s**t needs to be stopped sorry but its as simple as that .
:-D
