zx handling
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave1</i>
Thought you may be interested in this.
http://www.andyspares.com/discussionfor ... =zx,escort
Well since I started this topic as per the link.
60k down the road, 2 sets of quality tyres and new subframe mountings.
My opinion of the handling of the ZX is still the same, OK in the dry (oversteer) and scary in the wet (understeer). The thing I like about this car is its torquey performance, reliabilty and ecomony. Its a pity I can't add the corner handling to that.
- Contact:
Well the zx is very well respected for its handling. I guess its just what youre used to.
I doubt a zx elation has very wide tyres compared to other some other zx's and it wont have the same suspension setup as volcanes/16v's but still fundamentally wont be too much different. You can control understeer in the wet with smooth throttle control, you can lift a bit to bring the front back into line or left foot braking which will help a lot but takes a bit of practise.
Take a mk5 escort and a zx of similar engine performance, give them same tyres and 95% of people will tell you the zx will be quicker through the bends etc
I'm most surprised - ours - 63,000 miles - 1.9D seems exemplary under all conditions - tyres - continenntals on 3 wheels - cheap one on one back wheel. Its always been good even with barely legal tyres on the front when we bought it and an original Michelin for the first year on the back and has constantly surprised both of us with its grip especially in the wet. Mind you a plain 1.9 D is never going to surprise anyone with its acceleration and the brakes don't seem to get much use either in normal driving.
jeremy
jeremy
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by VisaGTi16v</i>
185/60x14 HR rating and uprated dampers.
The way I control the handling is by adjusting the tyre pressures to give a neutral handling ie: soft on the fronts and standard at the rear.
If you lift off in a corner you will induce the tail to pop out as its well known with front wheel drive cars, its the opposite, you should have a small amount of throttle to keep inline.
- Contact:
I dont know about yours but the book pressures for the 16v are 33 at the front and 31 at the rear and you have to believe Citroen should know whats best.
If you lift gradually and only a bit it wont oversteer unless youre really vicious with it.
You cant really complain that the handlings funny if you dont have standard pressures or suspension setup as it came out of the factory
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rossnunn</i>
The ZX is one of the best handling car's out of the box there is.
When you throw it into a bend, it feels like the back steps out, it doesn't of course, it just the rear beam doing its thing, the best way to 'feel' this is to enter a roundabout and exit it on the 3rd exit, half way round putting your foot to the floor, it feels odd to start with, but once you get used to it its sooo much fun!
mine really creaks and grumbles from the rear if I do stuff like that... does that indicate parts needing replacement?
- Contact:
That's right. It also depends on the type of tyres you got. I have Sumitomos SRIXON4 on my car and the pressures are listed as 32 all around. I use 40 front and 41 rear and the handling is now awesome. When using the factory recommended settings, handling was a little sloppy.
[/quote]
When you refer to Michelins, which ones have you got, there are various permutations are there not? I am about to buy tyres all round.
[/quote]
Michelin Energy; "latest" pattern (with a substantial groove down the centre).
Simon
Thanks Simon, been checking these out yesterday as it happens.
Dave
[/quote]
Simon
Dave
- Contact:
- Contact:
"I put mine upto 37/33 from 33/31 at a sprint event last year to combat some of the tyre roll."
If I am wrong, is this doing the same as what I said earlier about neutral steering in a bend. Except, I'll have a better ride not having the pressures so high at the rear and better traction. Mine are 33rear/28front.
