What is that under my bonnet!!!!!!!!!!!
Post Reply
pompelge
My Cars:
Post by pompelge »
Got myself another ZX, this time a TD. Anyway I was looking under the bonnet the other day doing the usual fluid checks etc when I came across a key switch on the left of the slam panel. Using the ignition key turns in on or off but I don't know what it turns on or off. It looks like a Citroen fitment. Couldn't find anything in the workshop manual. Any help unearthing its purpose would be appreciated.
wrinklet1
My Cars:
Post by wrinklet1 »
hi pompelge, I have a xantia and this has an ignition key under the bonnet.It is to isolate the alarm siren. You cab use it is the car is going in for a service or if you need to disconnect your battery.
Regards
Paul
np
My Cars:
Contact:
Post by np »
I 2nd the above.My 97 Xantia hasn`t got one,but older ones did.
PowerLee
My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2
Post by PowerLee »
Its a good idea to check that the switch is set to " ON " when your looking at purchasing a Citroen / Peugeot.
Often the alarm system is switched off because its gone faulty, But the remote locking a indicator flashing will still work.
The Peugeot dealer gave up on my 405s alarm in the end, Goes on in the middle of the night when its locked in a garage & blows fuse all the time, So I got a Cat 1 Clifford instead.
pompelge
My Cars:
Post by pompelge »
THANKS ALL VERY HANDY INFO
Post Reply
