PSA NAC RCC Updates
Re: PSA NAC RCC Updates
Thank you very much Marc. I shall try now.
Sorry but it doesn't work. Same thing as before, not valid.
I've followed the instructions, checked and checked again even went out with 4 usb sticks
. Just to save me running back and forth.
Process -
Format FAT32
Extract TAR file to USB stick
>> checked format which looks like this. (dated 27th Sep 2024 09:00)
SWL (folder) > long random number >
> Certificates
> Firmware
HashList.ini
>MediaHeader
UpdateInfo.xml
i added license folder
copied license file inside folder
Process -
Format FAT32
> Certificates
> Firmware
HashList.ini
>MediaHeader
UpdateInfo.xml
Morning,
Does anyone have any further ideas?
- x 6875
I can't help other than what has been said (also, just to clarify you are not using a MAC?), most others here have no issue, so make sure you have used a PC and tries the BSI Reset / Battery Disconnect / Reconnect Procedure.
Hi there Marc,
Thank you so much for all your help, as well as the files and procedures.
I have followed the instructions scrupulously but am still having trouble updating. Here's a summary of what I did :
At any rate, thank you very much for all your help.
Cheers,
Ramy
------------------- Contents of instkey_0D01121B89D4EE673DC4.xml --------------------
MIME-Version: 1.0
Content-Disposition: attachment; filename="smime.p7m"
Content-Type: application/pkcs7-mime; smime-type=signed-data; name="smime.p7m"
Content-Transfer-Encoding: base64
MIME-Version: 1.0
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
------------------- Contents of packageslist_0D01121B89D4EE673DC4 --------------------
Package: ovip-int-firmware-version
Version: 21.08.87.32_NAC-r1
Status: install user installed
Architecture: armv7a
Installed-Time: 1720376361
Package: map-eur
Version: 27.0.0-r0
Installed-Time: 1720371642
- Made 6 different USB sticks :
- 2 sticks with all files provided by you (at root : SWL, UpdateInfo, and "license" folder where I unzipped the license file)
- 2 sticks with SWL + UpdateInfo provided by you, but no license for OTA validation
- 2 sticks created with Citroen Update software
- Tried plugging them in, in that order - error messages are the same, "version not compatible with hardware"
- Then followed you BSI reset procedure :
- Used long timings : switch off, close doors, open window / 10 minutes / disconnect battery / 10 minutes / reconnect battery / 4 minutes / side lights / ignition / open door / engine on
- I got a boot screen, and time & date were reset, so I imagine the NAC properly resetted
- Then plugged in the USB sticks in the same order, but got the same errors
- Went to Settings > System Info > Export Config to get the files which I am dumping below (please forgive me if long dumps are not allowed, I can make a pastebin)
Cheers,
Ramy
MIME-Version: 1.0
MIME-Version: 1.0
Package: map-eur
Version: 27.0.0-r0
Hello, could I get the latest firmware update and key file for the infotainment system please, VIN VR3**************[VIN obfuscated, can be read by forum staff].
The car is a Peugeot 208.
Thank you so much!
Best regards
Thank you so much!
Best regards
- x 6875
RCC Firmware Version 6_0422_23.3I37.1
Steve Shomps Licence File
Instructions for Updating NAC or RCC Firmware, Maps & Licences
The update ran successfully!
Much obliged, Marc.
BR
- x 3
Hello,
Today I downloaded the screen update via Peugeot Update. The update was installed with the engine turned on and then I got the message: Firmware update failed
Version not compatible with hardware!
Please remove the USB stick!
I downloaded the update from this thread and added my file in the license directory.
4 pendrives and each time after a few seconds the same message.
I have to disconnect the battery before each attempt.
The car does not turn off and the battery discharges.
HELP!
VIN VF3**************[VIN obfuscated, can be read by forum staff]
HELP!
Hi
Very new to the party and after some update help if possible?
I I have just bought a 2017 Spacetourer Feel 8 seater and I’m trying to update the radio as it crashes when asking Siri to do anything and then comes back on!
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
I have tried to use the Citroen update on my Mac but all I get when I plug the usb into the stereo is hardware not compatible
The app on my phone is saying updates available
Map update (27.0.0-r0)
Operating system of the car (21.08.90.52_NAC-r0)
Please please please can anyone help or is it worth buying a new radio but will I lose the functionality eg tyre pressure reset (and yes I’m a proper noob) lol…
Hello good morning. I have a Citroen grand C4 space tourer , 2019 registration , 1.2 pure tech. No problem until now for updating sat nav and infotainment. But my feedback of the quality of the sat nav is very bad. Too much lag, address recognition is poor, and the overall view is that between this nav and Google maps I prefer definitely Google maps. Basically not a good option. Even with the updates, no difference seen until now.
- x 6875
Disconnecting the battery and reconnecting isn't going to work! You need to do a proper BSI Reset / Battery Disconnect / Reconnect Procedurefasi wrote: 08 Nov 2024, 19:21 Hello,
HELP!
When you are at the disconnection part, leave the battery off for a good 10 minutes. But before you do this attempt, make sure your car battery is not discharged. If it's over 5 years old it will probably be due for replacing.
You don't really need a licence file as your vehicle has built in Wifi, so will authorise the firmware update itself. Just make sure you leave the engine running throughout the process and that you have waited a few minutes after starting the vehicle before inserting the USB. Also, make sure you have not disabled the telematics system.
I have included the licence file below in case you have a problem with OTA authorisation, but do not mix licence files up - tey are specific for each firmware and vehicle.
Read the instructions in the link properly.
Firmware 21.08.90.52_NAC-r0
Fasi Licence File
- x 6875
First - DON'T use a MAC for this! Mac's put their own hidden system files on the USB and these can cause the updates to fail or not even start. Please use a PC for this operation.Plant38 wrote: 08 Nov 2024, 22:38 Hi
Plant38 Licence File
Map Update V27
Note: You do NOT need a licence file for map updates, so do not include this on the USB when updating the map only.
Please read the instruction in the link if using the licence file as the spelling of the folder and location are critical. Your vehicle has on-board WiFi for firmware authorisation, so should not need a licence file, but I am including it here if required. Please read the instructions thoroughly in the last link.
Hi thanks for this is will give it a go and let you know how I get in…!
- x 6875
I don't use them either as the voice recognition doesn't understand Welsh place names, so totally useless.mfcg wrote: 09 Nov 2024, 12:28 Hello good morning. I have a Citroen grand C4 space tourer , 2019 registration , 1.2 pure tech. No problem until now for updating sat nav and infotainment. But my feedback of the quality of the sat nav is very bad. Too much lag, address recognition is poor, and the overall view is that between this nav and Google maps I prefer definitely Google maps. Basically not a good option. Even with the updates, no difference seen until now.
I use Sygic navigation with my iPhone - the best system there is IMO.
