PSA NAC RCC Updates
- x 430
Re: PSA NAC RCC Updates
When I updated mine, I discovered you can not format a USB larger than 32gb into FAT32. A 64gb will format as EXFAT and it won't work
Thanx to Marc and all the admins & knowledgeable people that make this the best forum on the interweb.
- x 6846
Yes you can Steve, but you need to know how to do it
Microsoft limits native FAT32 formatting in Windows to 32Gb drives or less. This doesn't mean you can't do it though, but this format won't support individual files sizes larger than 4Gb.
Use a free tool like this:
https://formatusb.com/download
This will allow you to format USB drives larger than 32Gb to FAT32 and is basically what the PSA firmware update tool does behind the scenes - but you can't see it.
Just remember:
Just remember:
- Make sure you select the correct USB drive letter before using it!
- Make sure that when downloading any Firmware from my links, that you first download the compressed files to your PC first of all, then decompress the archive onto the USB afterwards. In other words DO NOT try and download the compressed firmware file from the link directly onto the USB drive - it will not work on a 32Gb USB because of hte 4Gb limit I talked about above.
- New User
hola Soy de Chile tengo un citroen c3 1.2 2017 y no puedo actualizar mi pantalla DEL CARRO
se apaga y se enciende sola, quiero corregir ese error y no me sirve la aplicacion my citröen
la descarga no me sirve.
EL vim VF7**************[VIN obfuscated, can be read by forum staff]
ME PUEDE AYUDAR GRACIAS
Google Translate:
Google Translate:
Hello, I am from Chile, I have a Citroen C3 1.2 2017 and I cannot update my CAR screen.
It turns off and turns on by itself, I want to correct that error and the my citröen application does not work for me
The download doesn't work for me.
EL vim VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
CAN YOU HELP ME THANK YOU
Reason: Translate text.
- x 6846
The latest Citroën desktop app seems to be working, I re-downloaded and installed version 0.1.24 from the Citroën website, it actually downloaded the update, detected my USB pen drive and is currently in the process of copying the update to the pen drive.
Where did you download the new version update thanksATOJAR wrote: 20 Apr 2024, 13:26 The latest Citroën desktop app seems to be working, I re-downloaded and installed version 0.1.24 from the Citroën website, it actually downloaded the update, detected my USB pen drive and is currently in the process of copying the update to the pen drive.
Hello, Marc!
My VIN is *****************
Thank you!
Thank you!
- x 6846
@mastodonte1:
There are no updates - you have the latest firmware (21.08.87.32_NAC-r1) and map updates (26.0.0-r0) available.
Hello Marc from Finland!
I just bought 2017 year Citroen C4. MyCitroen app said that I have two updates available. Map and firmware. Map update was ok and I was able to uploud it to the car. But firware load from the server does not start. As I have been reading this forum is it possible that you can help me with that firmware data. My VIN is VF7**************[VIN obfuscated, can be read by forum staff].
Timppa
Timppa
Hello,
could you please generate a licence file for me and check the latest firmware I could update to?
My VIN is VR3**************[VIN obfuscated, can be read by forum staff]
Thanks in advance,
mrTruly80
Thanks in advance,
mrTruly80
- x 6846
V 6_0422_23.3I37.1 Firmware
mrTruly80 Licence File
Instructions for Updating NAC or RCC Firmware, Maps & Licences
Hey,
I have a c4 picasso (2015). I'm fairly new to this and first time owning a french car.
I've searched whole internet for firmware and nav map updates.
I probably need licence too..
Can you help me ?
Can you help me ?
- x 6846
@marifah: Sorry, you don't have an RCC or NAC system, you have a SMEG system. This thread is only for NAC / RCC systems for which the maps are included for life.
Maps for SMEG are available from Citroen Navigation website:
https://citroen.navigation.com/home/en_ ... enEMEA/GBP
No need for firmaware. I got it from my dealer free of charge.
- x 6846
Sorry, I missed your post. If you have everything, then fine,
