PSA NAC RCC Updates
- x 6846
Re: PSA NAC RCC Updates
1) Did you leave the engine running? This must be done - if not the vehicle can go into economy mode and interrupt the firmware update.
2) How long did the update take? Should be anywhere up to 40 minutes, if a lot less, it hasn't completed.
3) Did you remove the USB at any time? Doing so can leave the system corrupt.
4) Don't play with any switches or controls during an update.
Check that all the files are on the system correctly (use the FULL POST EDITOR & PREVIEW button to upload a picture from your PC or mobile) and post it here for me to see the content of the USB.
5) Start the process again but make sure you leave it in the vehicle with the engine running until it tells you it is complete.
Followed the instructions on the screen, it took around 22 min.
Engine running and i left the car alone for the duration, when the update was done, i pulled the usb stick as instructed on the screen.
The instructions said that when usb stick is pulled the system will reset.
After reset i shuffled true the menus and when tried to enter the climate menu it just said something like: please wait initializing
I lef it there for 6-7 minutes and the choose to restart the car, cycle the power.
And now it won't even register that I press the climate soft button next to the screen.
Please see attached picture of software Installed.
I'm unable to restart the update, I says no update required.
UPDATE: I DISCONNECTED THE BATTERY TERMINAL AND LEFT THE CAR FOR 1 HOUR, now it works.
- x 6846
Great, sometimes a reinitialisation of the BSI can resolve this issue. But in future make sure you follow the BSI Reset / Battery Disconnect / Reconnect Procedure for the correct procedure if disconnecting the battery.
- New User
Have the same problem, trying to download uppdate bu the error "an error occured while retrieving update data. please check your connection settings" keep popping up.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Thank you
Thank you
- x 6846
Hello everyone,
I could not connect to the screen of my Citiören Berlingo vehicle with Android auto. I saw that there was a Screen update (6_0422_23.3137.1), I installed the Citroen update app on my Windows 10 machine and followed the on screen instructions, the problem appeared when starting the download, long before it had even downloaded anything "There was an error retrieving update data. Please check your connection settings "do it." A box will open saying: I can click "OK" on the box and then "continue download" but the same error box instantly reappears! I haven't been able to download it for 3 days.
My car is Citiören Berlingo 2019
VIN: VR7**************[VIN obfuscated, can be read by forum staff]
I would like a download link
- x 6846
Firmware 6_0422_23.3I37.1
Ziya Licence File
Extract contents ONLY to USB. Do not copy the TAR file to the USB or it will not work.
Next create a folder on the USB called licence or license (spellings vary - it will work with one of the other spelling) and then copy the licence file into this folder.
Keep the engine running - essential!
Ziya Licence File
Hello,
I have recently bought a Citroen C5X Shine Plus, 2023 model, and am loving it.
However, I've been having a few quirks with the software not quite working as expected, and have been informed there's a firmware release that may correct the issues.
My system software version is NHW.1.19.44.8, whereas I've been informed there's a version NHW.1.20.93.7 (or perhaps even later version now) that has British English (as opposed to American English).
I've read on here that there's potentially a manual way of updating the system and navigation software, however the Citroen website doesn't list a software download being available. Can anybody advise, please? My VIN number is VR7**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Best regards
Rob
Many thanks.
Best regards
Rob
Hello again,
Thank you for your support and the link.
- x 6846
Hi Robbikergsx wrote: 21 Feb 2024, 08:57 Hello,
Many thanks.
Best regards
Rob
Unfortunately you will have to sit tight, as I believe there is a considerable problem with one of the firmware updates that was initially released, which has caused almost total loss of functionality to some system with these vehicles where it was applied. It is my understanding that the firmware has now been pulled, which is why it is not available under your VIN direct from Citroen's servers.
I strongly suggest that if you do find a version later than yours on the general web from some unknown sites or forums, that you DO NOT attempt to install it. If you do, you may suffer the same fate and Citroen may decline to fix it, considering that if they have pulled the firmware and you have obtained it unofficially, that you may have caused the damage.
Wait for now until your app states there is a new firmware available for you to download. Some models can update OTA (Over The Air) in which case they will do so if and when an authorised update comes out.
If you are not sure - wait until your My Citroen App states there is an update available.
As it stands at my end I cannot provide the update for you as it has been pulled. I understand they are aware of the issues in France and are attempting to get a fix out as soon as they can.
hi im having trouble updating my touchscreen system in my brothers new car hes got a Citroen c4 cactus. im doing the download then as it gets to the end it says error please check connection settings? any help please
Many thanks for your reply and explanation, Marc. Much appreciated and I will take your advice to await the official release of the system software.GiveMeABreak wrote: 21 Feb 2024, 12:56Hi Robbikergsx wrote: 21 Feb 2024, 08:57 Hello,
I've read on here that there's potentially a manual way of updating the system and navigation software, however the Citroen website doesn't list a software download being available. Can anybody advise, please? My VIN number is VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Best regards
Rob
Keep up the good work.
All the best, Rob
- x 6846
No worries.
I note in another recent thread, that a member in Taiwan has had his system crash, but I believe the dealership has amended the original or an earlier firmware version's date and version number to allow then to reinstall the older version back on to get him out of trouble until a revised version is released publicly.
viewtopic.php?p=790648#p790648
- x 6846
I've moved your post here as it's not a new C4 model.declan_2001 wrote: 21 Feb 2024, 13:16 hi im having trouble updating my touchscreen system in my brothers new car hes got a Citroen c4 cactus. im doing the download then as it gets to the end it says error please check connection settings? any help please![]()
I'll need the VIN of your vehicle to check system you have and advise. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Thanks for the reply:
the vin is : VF7**************[VIN obfuscated, can be read by forum staff]
