Ah so no option to update at all?rui_saraiva wrote: 29 May 2025, 20:40 @sagor: Did you try the official "Citroën Update" software?
For macOS: https://d1tik0o5ahgjm.cloudfront.net/ci ... Update.dmg
For Windows: https://d1tik0o5ahgjm.cloudfront.net/ci ... 0.1.24.exe
This should download the firmware and respective license for your RCC Wave 2 system and prepare the USB flash drive.
Edited:
But you won't be able to install it. The latest firmware version for the RCC Wave 2, 1_076_16.1B116.4, is already 6 years old and has expired signing certificates:Just like the NAC Wave 1 and Wave 3 systems, you'll need to wait for PSA/Stellantis to (unlikely) release a new firmware with valid certificates.Code: Select all
> openssl smime -in rcc_update\Bosch.cms -pk7out | openssl pkcs7 -print_certs -text | head Certificate: Data: Version: 3 (0x2) Serial Number: 7 (0x7) Signature Algorithm: sha256WithRSAEncryption Issuer: C=FR, L=Paris, O=PSA Peugeot Citroen, OU=Certificate Authorities, OU=(c) PSA Peugeot Citroen - For authorized use only, OU=0002 319187308, CN=PSA - OVIP - Code signing - G1 Validity Not Before: Apr 4 13:02:52 2019 GMT Not After : Apr 4 13:02:52 2022 GMT
PSA NAC RCC Updates
Re: PSA NAC RCC Updates
I have the same issue and would be really grateful for your help and advice.
I have a C4 Cactus 2019 that previously belonged to my mother. I don't believe the software or maps have ever been updated and when I tried to do this using the Citroen.co.uk updates, I am got the infamous "Version not compatible with hardware"..
My local dealership who had sold my mother the car said they don't understand and couldn't help.
And Citroen customer services UK told me there were no map updates for my car, and that if the maps were out of date, I could always use Google Maps!
The current software is: 31.09.4662_NAC-rO
Looking forward to hearing from you.
Hello Rjp1205,Rjp1205 wrote: 17 May 2025, 22:40Well that didn’t work out as expected. The certificates still expired on 03 November 2024. I shall visit by dealer again on Monday and see if Citroen have replied to the technical ticket that they opened for this issue. I shall keep up you informed of my findings. The main dealers only have access to the same software that we do via the update app so there is no point paying them any money to attempt it.Rjp1205 wrote: 17 May 2025, 21:42 I have just checked the Citroen update app and it is now showing a version 42.03.33.42 as available. This is after it disappeared for a few weeks. I am downloading it now and will check the certificates to see if they are now valid before attempting update in my vehicle. I shall update on here once I know the info. Fingers crossed that it will work!
Where did you find that certificates expired on 03 November, 2024?
I really appreciate any help you can provide.
Kind regards,
Hello Rui,rui_saraiva wrote: 26 May 2025, 00:40risto bojchevski wrote: 25 May 2025, 15:24 Hi all,
I have a 2019 C4 Cactus with version 31.09.46.62_NAC-r0.
I would like to update to the latest system and map. I am from Skopje in North Macedonia.
Could you help me with this issue? Thanks in advance.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff].Both of you have a NAC Wave 3 infotainment system (firmware version 3x.xx.xx.xx), which is impossible to update at this moment (and in the last 6 months or so). This is not related to the license, but to the signing certificates (included in the firmware) that are expired/too old. Only PSA/Stellantis could fix this by issuing new certificates, signing their update with them (the private key), and releasing a new .tar file.izzy99 wrote: 25 May 2025, 18:53 Hi all,
I also have the "version incompatible with hardware". The Citroen update program says "PSA_ovip-int-firmware-version_42-03-33-42_NAC-r0_NAC_EUR_WAVE3" is the most recent update I need. My car has now version 30-05-50-42_NAC-r0_NAC_EUR_WAVE3. My VIN is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]. Please has anyone a suggestion?
Best regards,
Where can we find certificate expiration date?
While using the Citroen Update tool, I found the PSA-OVIP-CS-G1.crt file on the newly created USB location under SWL/00*/Certificate. Are you referring to this one or something else?
Thank you and kind regards,
I just tried to update my Spacetourer 2019 Firmware as well (always had issues with Apple Carplay and Voice commands), which fails (incompatible hardware) Reading through this thread I found that likely some certificates are expired and thus no update can be performed, although the Citroen App suggests to do so. I'm also wondering what Version (Wave2/3 this car has).
When I export settings from the car I get this:
That firmware version suggests a Wave 3 or a late Wave 2? I found that I should update to 21.08.90.52_NAC-r0, which is despite the lower number a newer firmware for this model?
The official Software Update suggests to update to 42.03.33.42_NAC-r0 (also fails).
Now I really think I'm affected by the old certificates? Could certificate expiry be tricked by changing the NAC's time?
Is the Update Software / Mobile App broken? Why does it suggest to Update to 42.x.x.x when everyone here suggests that 21.08.90.52 is the latest FW for this model?
Code: Select all
Package: ovip-int-firmware-version
Version: 31.09.46.62_NAC-r0
Status: install user installed
Architecture: armv7a
Installed-Time: 559
Package: map-eur
Version: 6.3.0-r0
Installed-Time: 96
- x 3
Hi, I extracted the info below from one of the files. I can’t remember which one off the top of my head.subasha wrote: 03 Jun 2025, 11:21Hello Rjp1205,Rjp1205 wrote: 17 May 2025, 22:40Well that didn’t work out as expected. The certificates still expired on 03 November 2024. I shall visit by dealer again on Monday and see if Citroen have replied to the technical ticket that they opened for this issue. I shall keep up you informed of my findings. The main dealers only have access to the same software that we do via the update app so there is no point paying them any money to attempt it.Rjp1205 wrote: 17 May 2025, 21:42 I have just checked the Citroen update app and it is now showing a version 42.03.33.42 as available. This is after it disappeared for a few weeks. I am downloading it now and will check the certificates to see if they are now valid before attempting update in my vehicle. I shall update on here once I know the info. Fingers crossed that it will work!
Kind regards,
I used OpenSSL to view the file :-
Validity
Not Before: Nov 3 14:38:04 2021 GMT
Not After : Nov 3 14:38:04 2024 GMT
- x 13
It depends on the hardware. For the NAC, the signed file is "SWL/00*/MediaHeader/MediaVersion.ini" (on RCC systems it's the "rcc_update/Bosch.cms", AIO the "aio_update/Bosch.cms" and RCE the "RCEUpdate.xml" file), so if you runsubasha wrote: 03 Jun 2025, 11:25 Hello Rui,
Code: Select all
openssl smime -in SIGNEDFILE -pk7out | openssl pkcs7 -print_certs -text
The "SWL/00*/Certificates/PSA-OVIP-CS-G1.crt" file is the public key certificate that is used to verify the identity and the authenticity of the software. To digitally sign the software, PSA/Stellantis used the other half of the equation - its PRIVATE key. You can download the latest public key from http://pki.p3cs.com/PSA-OVIP-CS-G1.crt but that's not the problem. The software MUST be digitally signed with the private key that pairs with that certificate, and only PSA/Stellantis has access to that private key.
- x 3
hello. and as you said about pressuring Peugeot, so I did and Peugeot calls me to the service and tries to update itself. I've already been there once but they couldn't do it. I'll be called to ASO a second time when there's another solution. generally, even if they fix the certificates, it won't be globally but for a given VIN number because it's easier to fix the car for one user who reports a problem than for one user to fix all the software, so I suggest going to ASO and harassing Peugeot. I wrote an e-mail to Peugeot Polska.
Hi. I am having the same issues when trying to download the update from 'Citroen Update'
Can I please have the files too?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thank you!!
Marshall
Thank you!!
Marshall
Thanks a lot, Rui!rui_saraiva wrote: 05 Jun 2025, 13:32It depends on the hardware. For the NAC, the signed file is "SWL/00*/MediaHeader/MediaVersion.ini" (on RCC systems it's the "rcc_update/Bosch.cms", AIO the "aio_update/Bosch.cms" and RCE the "RCEUpdate.xml" file), so if you runsubasha wrote: 03 Jun 2025, 11:25 Hello Rui,
Thank you and kind regards,(replace the SIGNEDFILE), you should see the validity dates.Code: Select all
Yeah, the certificate expired in November last year, so we cannot do anything. So I can wait (and hope that a new certificate will be issued), or go to the official Citroen service and pay them to do the necessary updates.
Kind regards,
Hi guys,
As most of you i have got the same problem with my DS7 Crossback (12.2019) : version is not compatible with hardware.
Tried it 3 times, with 3 different usb flash drive.
I currently have the version 31.09.46.62_NAC-r0 and the update i am downloading is version 42.03.33.42_NAC-r0
My VIN is VR1**************[VIN obfuscated, can be read by forum staff].
Help, please:)
Help, please:)
- New User
Hi I'm looking for help with my 2019 Berlingo for files I can download to update as it is not working through the Citroen app.
Vin: VR7**************[VIN obfuscated, can be read by forum staff]
Any help would be much appreciated
John
John
- New User
Hi guys,
As most of you i have got the same problem with my C5 Aircross (12.2019) : version is not compatible with hardware.
Tried it x times, with 2 different usb flash drive.
My VIN is VR7**************[VIN obfuscated, can be read by forum staff]
Help, please:)
Help, please:)
And how did it go?BrayanLDZ wrote: 08 Jun 2025, 08:51 hello. and as you said about pressuring Peugeot, so I did and Peugeot calls me to the service and tries to update itself. I've already been there once but they couldn't do it. I'll be called to ASO a second time when there's another solution. generally, even if they fix the certificates, it won't be globally but for a given VIN number because it's easier to fix the car for one user who reports a problem than for one user to fix all the software, so I suggest going to ASO and harassing Peugeot. I wrote an e-mail to Peugeot Polska.
Good afternoon,
I’m facing the well-known issue during firmware update on my DS7 Crossback.
The DS Update app offers a newer firmware version (via VIN recognition), but when I try to update via USB, I receive the error:
> “Version not compatible with the hardware”
My current firmware is:
31.09.46.62_NAC-r0
(original factory version, from 2018)
USB structure is correct:
SWL folder with appropriate subfolder and firmware files
Valid UpdateInfo.xml in the USB root (with VIN)
FAT32 flash drive
I understand from the forum and other sources (e.g., frenchcarforum.co.uk) that the root cause might be an expired firmware certificate.
Could someone please confirm:
Which intermediate firmware version is still installable in 2025 (e.g., 21.04.62.54 or 21.08.87.32)?
Is there a known working 42.03.33.42_NAC-r0 version with a valid signature?
Many thanks in advance
VIN (available for forum staff if needed): VR1**************[VIN obfuscated, can be read by forum staff]
31.09.46.62_NAC-r0
FAT32 flash drive
