citroen c5 x7 2008
Sergiu
Re: citroen c5 x7 2008
Post by Sergiu »
GiveMeABreak wrote: 20 Feb 2024, 22:51 DO NOT bypass the fuse! This may cause a fire otherwise - this is why we have fuses. I suspect your pump motor has been contaminated with LDS fluid which can seep in from over spills from the LDS tank. The oil then mixes with the worn carbon dust to create a paste that then causes overheating / shorting out.
Have a look at this very detailed post with photos to show the repair:
viewtopic.php?p=581404
I mentioned in a message above that I removed the pump open and cleaned it. thank you for trying to help,
Sergiu
Post by Sergiu »
Kees wrote: 20 Feb 2024, 10:45 Well, I'm sorry to tell you, but if this fuse is blown, 9 out of 10 means, that the pomp is broken. This fuse is 40 A.
Greetings,
Kees.
I will like to know what is the other 10 % means
Jay-Bruce
(Donor 2022)
x 244
Post by Jay-Bruce »
Replace the fuse, and disconnect the electrical connections of the pump. Then start the car, rev the engine, and stop the car. If the fuse has blown again, it would suggest it is achieving a shirt to the body, so you'd need to look for damaged wiring between the fuse box and the pump.
Kees
x 11
Post by Kees »
Marc has 100% ,right!!
If this fuse has blown, this means the pomp motor turns to have, and because of this the power dissipate is much higher then!
The max power the fuse can handle must be below 480 watt.
Greetings,
Kees.
Sergiu
Post by Sergiu »
Kees wrote: 21 Feb 2024, 13:46 Marc has 100% ,right!!
Greetings,
Kees.
I will probably take of the pump again and look inside one more time, maybe i miss something, maybe i should clean it better
Sergiu
Post by Sergiu »
Jay-Bruce wrote: 21 Feb 2024, 10:15 Replace the fuse, and disconnect the electrical connections of the pump. Then start the car, rev the engine, and stop the car. If the fuse has blown again, it would suggest it is achieving a shirt to the body, so you'd need to look for damaged wiring between the fuse box and the pump.
that's a good way to find damaged wiring actualy, very smart, I will try this, thank you
Jay-Bruce
(Donor 2022)
x 244
Post by Jay-Bruce »
You're welcome buddy, let us know how you get on :-)
Sergiu
Post by Sergiu »
Can you please send me a wiring diagram for the citroen that i have, and for the pump also? thank you
x 5741
Post by GiveMeABreak »
We don't send wiring diagrams, but I'll put up the relevant one here for you shortly if this is for your 2008 DW10BTED4 X7.
7739: Central electronic block motor
1524: Supply cut-off relay /
Most hardware codes can be found here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
Sergiu
Post by Sergiu »
GiveMeABreak wrote: 26 Feb 2024, 18:47 We don't send wiring diagrams, but I'll put up the relevant one here for you shortly if this is for your 2008 DW10BTED4 X7.
Thank's Man, one more question I have, ( is for everybody ) My pump motor is aparently gone (broken ). Do you (all) know where I can get a electric ( motor only ) for the pump, because new pump together is to expensive, my car doesn't cost that much. Maybe an online shop for French car parts where I can buy the electric motor only, Thank you
x 5741
You probably need to take it apart and clean it up to remove all the carbon paste that is shorting it out.
Have a look at EDC5's guide here:
viewtopic.php?t=60565
Sergiu
Post by Sergiu »
GiveMeABreak wrote: 17 Apr 2024, 16:40 You probably need to take it apart and clean it up to remove all the carbon paste that is shorting it out.
i did that allready, did not help
x 5741
So you’re saying you’ve cleaned it all up and there is no power to the motor? Which fuses have you checked?
Sergiu
Post by Sergiu »
GiveMeABreak wrote: 17 Apr 2024, 22:10 So you’re saying you’ve cleaned it all up and there is no power to the motor? Which fuses have you checked?
I don't say there is no power to the motor, there is but the motor won't turn, something is bad in it, I open it and I can see some melt plastic, I clean everything but does not start, when I connect directly to battery starts but turns slow, I don't want to open it again, it won't make any diference, just want to change it if I find one, thanks
x 5741
Sounds like it has been overheating and has continued to be used, so has done more damage.
