wheeler wrote: 20 Apr 2024, 22:11
Rhothgar wrote: 20 Apr 2024, 15:35
Managed to get the HDi running at full boost last weekend but still getting horribly high air flow at idle.
Is it running fine now but you just have high air flow at idle? If its not over 500 mg/cp leave it alone.
Every RHZ engine i have owned always had an air flow at idle of 500 mg/cp
You see! I’m having sleepless nights thinking about the car
I cannot measure it due to OBD issue but it was around 470 last time I was able to measure.
My focus on this has now turned to fuel economy and what I believe are abnormally high throttle position percentages under conditions where the throttle is being ‘tickled’.
Wish you’d have seen my other post as I ended up buying a new Lucas air mass meter on Wednesday. Fitted it Friday so cannot return. It made no difference to the reading when compared to the famous £8.08 Intermotor one I bought in August. Never mind.
Because of communications issue with Lexia, I’m now thinking of taking the dash out to repair the damage to the 2-3 OBD terminals that has occurred back in August. The ELM327 module I have works or did, at least, yesterday morning. Some of the tangs with the terminals have folded back. When I had issue last year, I stripped each wire out and prised them closer. That and the insertion of a cheapo ELM module with male terminals that probably aren’t the best tolerance has probably done more damage when all that was wrong was my Lexia was dying.
I wish there was someone near to me that had a Lexia so I could check whether theirs reads before I create myself a mammoth job!
Mind you. It needn’t be too near as I could brim the tank and check MPG over a longer distance but that sort of defeats the object of reducing fuel usage.
Basically plugged Lexia in again yesterday to actually test if anything changes reading wise when vacuum is manually applied to the EGR. Apparently the air flow should drop by about a third as it adjusts.
One thing I should really check is the intercooler for leaks. I checked all the pipes from the turbo to and from it last weekend. Had a thought that the whistling I hear, ie the turbo spinning, could be either that or a leaking inlet manifold gasket. I did buy a new gasket last year as I wanted to remove the manifold and check if it is badly restricted as if the wrong amount of air is actually getting in then that could result in the poor mpg. Also, the ECU might be overfuelling because of the high airflow at idle. Pretty sure the air flow is probably high across all the range? Stands to reason, surely?
The signal voltage of pin 5 of the air mass meter is too high at 2.42 bolts at idle. It should be 2V I believe.
Also did a leak-off test on Friday. They were all roughly equal but 45-50 once the diesel from the pipe had drained into the bottles. Excessive leakage doesn’t lead to high fuel consumption but neither does it rule out poor spray pattern.
