brake doseur
tj
brake doseur
Unread post by tj »
After much tracing and diagnostic, I have to conclude that my brake doseur is the culprit for fast ticking. The return pipe is practically gushing LHM. The thing that really annoys me was that the doseur is only a little over a year old. At first I thought it might have been due to dirt jamming up inside causing the valve not closing properly. Now that the car is on hydraurincage for over 3 weeks, there is no improvement at all. Can the valve be over hauled? Can wrongly connected pipe cause this problem? (the car 's hydraulic feels normal apart from fast ticking and gushing return pipe).
http://www.alllinuxcd.com
tomsheppard
Unread post by tomsheppard »
This isn't the first time I've come across nearly new Doseur failures. This is the fourth in a year. I suspect that the last ones were made on worn out tooling. Vexing, though isn't it?
