1994 Xantia 1.9TD, 115k miles. Has started cutting out on the odd occasion. Seems to occur after descending a hill in gear using engine breaking. When you put the clutch down the engine stalls. No problem restarting either by letting the clutch in or on the starter. Anyone any similar experiences or suggestions? At the moment it is not really a problem as it happens so infrequently, but I suspect it is going to get worse and become annoying.
Rory
Diesel Cutting Out
nick
Could be air getting into the fuel pipes somewhere, I had a similar problem with a BX diesel which would often stall when coasting to a stop at the end of slip roads after a long motorway run. On the BX it was the fuel heater letting air bubbles into the diesel, which slowly filled the filter with air. When the engine speed dropped this air was sucked into the injector pump, causing the engine to stall.
Nick
Nick
Stuart McB
rory_perrett
Stuart
Interesting you should mention the idle adjustment. My initial reaction would be to say its fine. Tick over is OK and this cutting out has only occured four or five times over the last 3 months. However we've had the car about 2 1/2 years and when we first got it it did tick over quite fast around 1100 - 1200rpm. While I wondered why (there usually a reason) I just adjusted it down and since everything was OK I didn't really give it much more thought. I know its probably only covering up the problem but I may try tweeking it back up a bit.
Rory
Rory
davek-uk
wrinklet1
rory_perrett
oilyspanner
bxbodger
One further possibility you could check is whether the physical movement of the clutch pedal, arm, cable (both inner and outer), etc, is causing the temporary disturbance of any electrical connections; it could be that the movement of any of these things is disturbing the stop solenoid wiring or immobiliser circuits temporarily. Going down hill could cause the loom to shift slightly in position, contact is made, and a short occurs.
ScottFromNZ
wrinklet1
cycaduk
