Guys,
One of my alloys is pretty badly scuffed. I wasw wondering is there spray, paint or another easy fix that I could use.
Cheers
Scuffed Alloy Wheels
philhoward
Apparently you can get an alloy filler; something like Chemical Metal or JB Weld, I think. Normal spray cans can be used quite well after rubbing down; just apply lots and lots of thin coats to build up the paint, and check for rection between the old paint/brake dust and the new paint (try a primer first?)
Kowalski
Stuart McB
jeremy
philhoward
The best way is to get them stripped, blasted and powder coated as Kowalski says. As a DIY clean-up type operation though, an etch primer and spray cans can be used. The finish won't be superb, though. Prices for pforessional refinishing vary from £20-100 per wheel, depepnding upon size, pattern, and their general state.
