Knock sensor
Post Reply
Stempy
My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX
Contact:
Knock sensor
Post by Stempy »
Anyone know what the resistance reading of this unit should be?
ItDontGo
My Cars:
Post by ItDontGo »
It wont really have a resistance reading. Its a piezo-electric device like in those annoying musical birthday cards. I would not know how to test one.
Stempy
Not missing the AX
Contact:
Post by Stempy »
Probably why it reads in the mega ohms region then.
AndersDK
My Cars:
Post by AndersDK »
It would produce (ac) voltage on mechanical knocking, i.e. holding the sensor against the body of an air impact socket driver.
xantiav6
My Cars:
x 3
Post by xantiav6 »
I think the way to test a knock sensor is to run the engine with a timing light attached, then tap the sensor with a screwdriver and watch the timing jump back.
I don't think this is a likely cause of a misfire.
regards,
Mike
Stempy
Not missing the AX
Contact:
Post by Stempy »
Probably not the cause of a misfire as you say, but just wondered what it should read. I think I might try the crank speed sensor first.
Post Reply
