This weekend I decided to see if I could sort the suspension out using the Dog box software. I don't have the special measuring equipment, or a 4 post lift, so I had to do it by eye.
This is what I started with.
When I opened up dog box, it took me a while to figure out how you modify the settings. But with some experimentation it seemed if you entered 160 for the front, and 105 for the rear, the software did not modify the position. So then by entering figures below these two you can raise the car, and by entering figures above you can lower the car.
After 30 mins of tweaking, I settled on this for my Citroen's stance.
I cycled it from min to max 4 or 5 times, and it settled a little higher than that. But it still looks pretty spot on.
So with that done, I decided to continue the interior clean. I thoroughly cleaned the front passenger side, after finishing the front drivers side.
This layer of muck was all over the steering wheel rim (and felt very sticky), on both stalks and in some other places one would touch. I can only assume the last owner used to drive with very grubby hands!
But is cleaned of relatively easily.
Bit of cleaning on the passenger side.
Well until I saw all this between the backrest and cushion...
So I cleaned all this up, and the front is looking pretty good now.
So then I spent a little time on the back, before it started spitting with rain...
So what did I do?
Clean the wheels of course
I don't mind a little rain...
But then it stopped and the sun came back out. So I decided to give the whole car a wash.
Being able to lower the car so I can get to the roof is handy!
Had the car looking much better after a quick bath! A few pictures in low rider mode.
Then had to take some more at the proper height.
