Zeljko
Sorry to hear your tale of woe. Let's hope if you try RichardW's advice then that might be the answer for you.
My friend's engine is def a 2.1TD.
Derek
xantia 2.1td problems with revs
Full fuel tank--------k light came on 4 times on my way to garage
starting from cold------k light came on 4 times on my way to garage
2 pedal/throttle sensor changed--k light came on 4 times on my way to garage
New coolant sensor(only one witch is green)---yeah yeah i know K light.....
This morning left it in (un)capable hands of main dealer to check wiring......
dave.t
how is it going with your coolant sensor?
Watch this DREAD
dave.t
Watch this DREAD
i'm smiling from ear to ear
fitted the sensor today done about fifty miles and not a sign of the prob.revs dead smooth even seems faster.nobody looking at me strange at the traffic lights as if i'm trying to race them .began to remember why i like this car so much.
Zeljko
your fault sounds exactly the same but my k light has never come on.did it light up before u had it in the dealers???check that they have definatly changed it (PART NO.1338 78 STOCK SENSOR ENGINE)and not fobbing u off.good luck in your quest this has taken me 3 months((1 diesel filter 1 diesel pump 1 coolant sensor 1 throttle sender 1 air filter 1 stock sensor (1 local garage 1 main dealer 2 diesel specialists)2 get to the bottom of.
Kered
WHAT A STAR.
i'd like to send u a bottle of your favourite tipple if u want to post your email address.
if not thanks again.
Zorgman
as you've probably gathered don't think i'll be needing the ecu anymore.thanks for your patience.
thanks everyone whose posted and got to the bottom of the problem ,lets hope we find the cure for Zeljko
cheers dave.t
Zeljko
Kered
WHAT A STAR.
Zorgman
cheers dave.t
yes k light used to come on before i took it dealer
but with restarting of engine it would go away
Tomorow they will change conector on the throttle swich/pedal sensor side because they could not find fault with wiring and that is apparently sugestion of "main main CITROEN" office before they change ECU.
Yeah they just told me that i have Lucas ECU and not Citroen ECU(if it was so good why would anyone changed it-previos owner!!!???)
I wonder what did they look at all this time if they discovered just now that ECU is not original one!?
Talking of competence?! All they wont is changing oil and filters!!!
Great news DAVE.T i am glad at list one is out of the woods.
Zorgman
stay in touch i might be a customer for that ECU who knows.
Still traveling on Saturday time is runing ou............
Watch this tread(Dread)
Zorgman
OK!
Got my car back...............
Conector wich they wanted to change didn`t arrive so they just did rewiring of old one.
So far so good ........
Thanks a lot guys i am off tomorow and coming back on 16/08 so you can expect at least one more time to hear from me just to confirm is the car ok now and spare another Citroen owner of MAIN DEALER Misery.
This tread continues on 16/08/2004
Watch this Dread
Watch this Dread
<font size="3"></font id="size3">
hi Zeljko
i had a problem with my xantia 2.1 td (erratic acceleration).
took it to a diesel specialist who told me that he'd cleaned all the electrical connections .(i guess he means the sensors connections )
so far drove it 20 miles problem seems to have gone
hope this helps
hi Zeljko
hope this helps
hi everyone
been suffering with the same problem
and i found that my pipe from the air filter was split open
put some tape around it
now its fine
the problem reappeared and i fitted what dave t mentions in his post (PART NO.1338 78 STOCK SENSOR ENGINE) six days ago
seems fine now ,
thanks everyone, especialy dave t
hope this helps
hi everyone
now its fine
seems fine now ,
hope this helps
