C8 2.2HDi really hates hills - turbo or DPF issue perhaps?
Donor 2023
x 2255
Re: C8 2.2HDi really hates hills - turbo or DPF issue perhaps?
Post by Hell Razor5543 »
I don't know, as my Rev B Lexia will only go up to v7.15 and works properly (even though it should only go to V7.14!).
Huskyxantia
Donor 2023
x 250
Post by Huskyxantia »
My version is a lower version as like what Hell Razor5543 said modern versions seem to not want to do what you want them, i had to roll back to an older version last year and i had more simpler functionality and it ran smoother too... on another note i do like my maxicom machine it does lots more and faster.
Donor 2022
x 458
Post by Rp0thejester »
I've run the car through the laptop I have. I'm currently on V7.62 but I don't think it's high enough. I tried Lexia, wow was that from the 70s!!! It said no to everything apart from Injection? Looked at it and basic faults. So I restarted the app and selected diagbox at 7.62. 11 codes later... 3 stupid bsi ones, 1 I can't remove is F something because coolant is to low, rubbish. 2 for tyres which don't bother me as I removed the internal tyre pressure sensors as stupid with the metal valve sticking out that snaps easily! The only issue is P1404 which is EGR which I expected. The problem I have is how the fck do I reset the FAP counter!
Huskyxantia
Donor 2023
x 250
Reset it , aslong as the pouch is full your be ok , egrs are a pain in the arse.
Donor 2022
x 458
That's the problem, I don't know how to. It took me awhile to figure out on diagbox that I don't have a C8, I have a C8 CAN. I think that's short for C8 CAN and will draw blood, sweat and tears from you when you try to work on it.
Huskyxantia
Donor 2023
x 250
Youtube it.
Donor 2022
x 458
:rofl2: :rofl2: I'll have time tomorrow but knowing me once I find it on YouTube I'll get sucked into the YouTube wormhole and not accomplish anything
tearing hair out
Donor 2023
x 13
Post by tearing hair out »
Huskyxantia wrote: 30 Aug 2023, 14:36 I may of solved your issue check the element inside the maf sensor ... is there one or has it burnt out.
It took me a week or so to spot this, and than many more weeks to finally give up trying to work out which safe place I put my Lexia in. This morning, I speculatively unplugged the MAF, expecting the car not to run. And it's TRANSFORMED. Seems to run perfectly and climbs hills with ease.
I suspect it's running a bit rich, but not sure. I don't really understand how it's running at all without the sensor.
Anyway, I shall now go and source a replacement. Thank you! (I'm kicking myself for not trying this months ago - but it was giving a reading which looked rational with Lexia, so I thought it was working.)
tearing hair out
Donor 2023
x 13
Rp0thejester wrote: 27 Sep 2023, 18:43 That's the problem, I don't know how to. It took me awhile to figure out on diagbox that I don't have a C8, I have a C8 CAN. I think that's short for C8 CAN and will draw blood, sweat and tears from you when you try to work on it.
Mine seems to talk both "C8" (VAN I think) and "C8 CAN", but it only detects the VIN in "C8" mode. However, in C8 CAN mode, the data polling rate is quite a lot higher, so I started to use that when I realised.
tearing hair out
Donor 2023
x 13
Oh and a side note on the dangers of Lexia. I've had a "1 tire pressure sensor missing" error displayed pretty much since I bought the car. While I was in doing diagnostics a month or so ago I thought "I'll just take a look at make sure I can't reprogram that missing sensor" (in case it's not a battery fault). So now I have "4 tire pressure sensors missing". ;-)
x 2939
Post by myglaren »
If the MAF is unplugged the ECU goes into default mode. As you have discovered a quick and easy test to see if the MAF is functioning correctly.
If you can access it you may be able to clean it. I used carburettor cleaner but ther is now a dedicated MAF cleaner (same thing I suspect).
Mine was ailing as the wheel arch liner had exploded and exposed the air + water, grit and leaves intake and made a mess of the MAF and filled the air filter with water and roadside crap.
A couple of squirts and it was OK. Don't touch the wires with anything other than the spray and don't drop or shock the MAF, they are exceptionally fragile.
Huskyxantia
Donor 2023
x 250
tearing hair out wrote: 28 Sep 2023, 09:25
It will revert back to default settings , not sure if it would pass an mot as the emissions will be slightly higher.
Huskyxantia
Donor 2023
x 250
myglaren wrote: 28 Sep 2023, 10:10 If the MAF is unplugged the ECU goes into default mode. As you have discovered a quick and easy test to see if the MAF is functioning correctly.
Wow that did need a clean .
x 2939
Post by myglaren »
Certainly did but worked OK for years after.
tearing hair out
Donor 2023
x 13
I'll take it off tonight and see if it looks cleanable (rather than just broken) - thanks.
And yes, I suspect it will not pass the MOT. On Tuesday...
