Well, I cleaned the holy sh*t out of it and put it back together. Half way through sticking it together, a neighbour happened along with a poorly mower. I got it fixed and waited for him to come back.
Finished the build, then took on the ABS issue... and that's where the s**t hit the fan
The screw would NOT come out. Ended up removing the hub and smashing out the old ABS sensor, then the damn bolt head broke off trying to remove it, so drilling it out and junior made me jump, snapping the bit (yes it was in the pillar drill, but it was precariously balanced). Remembered I had a Dremmel type tool and small metal cutting heads, so dealt with that. Tapped the threads back in and found a bolt to fit. Cleaned up the sensor bed and fitted the new one. Installed the hub & all that that involves. Tested it and...... SUCESS!!! ABS problem cured, but warning on dash with the legend Engine Problem (or whatever). I knew I heard a funny noise
I have a leak at the joint between the DPF & the DOC so guess what "I'm" doing tomorrow
The gasket ring didn't look very worthy anyway, so here we go again
](./images/smilies/eusa_wall.gif)
