This only adapts a non-hydractive 3.5 diameter pipe to the hydractive strut top.darbuck wrote: 02 Oct 2024, 12:15brilliant hopefully that's it sorted now and with it adapted to hydractive you will get longer out of it. Nice handy little mod.
Now despite the rubber seal being horrendously split and torn, I’ve fires the car up and there is no leak.
Need to find some LHM compatible pipe now and cut some new seals. I think unreinforced fuel hose is fine. I begrudge paying £3 for a seal although if I bought four it works out at just over £4.20 a piece with postage.
I have an imminent issue with the HDi. It stopped once after about a minute the first time and then
another couple of times within 10 seconds of starting.
I suspect it is a wiring issue or the double relay is on its way out. I’ll have to wait for it to fail fully before I can be bothered to diagnose it.
Might even be linked to this strange transponder issue that I noticed the other day.
