Hi RogerRhothgar wrote: 09 Sep 2024, 11:40 I take it you don't have a Lexia because presumably if you did it would then show the injector flow correction in the same format.
I had this issue trying to work out mg/cp to g/s for the airflow meter on my Xantia with some complex maths so it would be easier like you said already if someone has the same engine and could provide sample data for their engine.
The one issue I have is if you did have the engine running smoothly at one point why after a turbo change has it all gone to pot?
Worth starting another thread I guess so find out if yours is an RHR20TEDVCEDU or whatever the exact engine code is and ask for someone with the same engine code. I'd have thought between RHR engines and even RHZ engines there will not be much difference because at the end of the day all these cars of the same size with the same capacity RH engine will run largely identical with approximately the same fuel efficiency at idle especially when you consider they will be similar MPG's at 56mph with slightly differing aerodynamics. The point I am getting at is at idle there are no such resistances.
I'll see what I can find. It's a shame I haven't got a Diagbox. I was thinking of getting a replacement Lexia unit ie the latest gold chip one but have been more tempted towards getting a Kingbolen K10.
My mate has several different pieces of diagnostic kit but I'll have a look at his Bosch KTS unit which may well have the right data on. In the meantime, let me know the exact ECU your vehicle has. Is it a Bosch EDC15 or 16 or perhaps a Siemens?
Mine is a Delphi DCM 3.5
