x 1865
Unread post by MattBLancs »
Ok, possible breakthrough/alternatively search approach:
607 shares same strut bearing, so had a trawl on
https://catalogs.ssg.asia/peugeot/?lang ... BwbGllcj09
And 503147 is listed above as spring cup to suit the 607 too!
And the 607 was made for longer (hence hopefully less rusty versions are being broken for spares!)
c16rkc
Donor 2023
x 98
Unread post by c16rkc »
As much as I hate the idea of you causing misery to that sad looking "Prince Harry" spare coupe... I think that would be my choice for a part... being as it would be free :lol:
c16rkc
Donor 2023
x 98
MattBLancs wrote: 25 Oct 2023, 13:58 Ok, possible breakthrough/alternatively search approach:
Sounds good!
x 1865
Take the small wins today!
viewtopic.php?p=774002#p774002
x 1865
Thoroughly (twist knot angle grinder) wire brushed strut. Coated in phosphoric acid
Wondering if this bump stop has been shortened, or this is generally how they tend to fall apart??
Just looks rather neat!
Other than some powdered foam dust, no sign of missing bit. Dust shield intact
x 1865
Post phosphoric, ready for paint
x 1865
Second hand Peugeot 607 complete strut = best offer accepted, just paid (eBay)
Interestingly, despite being 2 years older, the other Coupe's drivers side spring looks very much healthier. Awkward to see, but may take the strut(s) off and, if as good as the spring, borrow the top seat (the 607 one could end up in that Coupe instead)
x 946
Unread post by Rp0thejester »
I must have missed something, the 607 parts are compatible with.....???
x 1865
Rp0thejester wrote: 25 Oct 2023, 18:23 I must have missed something, the 607 parts are compatible with.....???
No problem, went all over the place seeking a solution to my rusty problem!
406 Coupe, front suspension upper components, info courtesy of Marc of course!
GiveMeABreak wrote: 25 Oct 2023, 12:53 That boat's sunk Matt: :cry:
(4) Shock Absorber Ball Thrust Bearing, part: 503554, (NFP)
(5) Shock Absorber Bracket, part: 503866 (NFP)
(6) Front Suspension Rest Cup, part: 503142 (NFP)
(7) Shock Absorber Fix Cover, part: 503533 (NFP)
(8) MUL Bolt with Captive Washer, part: 503613
(9) Front Suspension Rest Cup, part: 503147 (NFP)
And from here:
Peugeot 607 front suspension upper components:
GiveMeABreak wrote: 25 Oct 2023, 15:44 Image
(4) Part: 503554 (NFP)
(5) Part: 5037C0, NFP)
(6) Part: 503147 (NFP)
(9) Noise Deadening Mounting Part: 503364 (NFP)
(Again, thanks to Marc!!)
As you can see, there's a little bit of overlap between the two.
Spring: different (does not have "pigtail' at bottom of smaller diameter, unlike the 406)
Damper: different (to suit spring)
But the bit I need "front suspension rest cup" confusingly number 9 on the 406 diagram and number 6 on the 607 diagram = 503147 = common to both!
x 1865
I only picked up on this as my new strut top bearings (equivalents not genuine, but would be 503554) mentions both 406 and 607 on the packet! :)
x 1865
Latest news, C5 spotted in "normal" estate car duties
207cm boxes provided a challenge (with 4 in the car too!
:rofl2:
x 7433
Love it :lol:
c16rkc
Donor 2023
x 98
Ah that's better... what a nice post for me to read... :-D
Appreciation for the beauty of the C5...
I'm expecting you'll be caressing conditioner into the leather, and buffing swirls from the paintwork this weekend.
x 946
Omg, we've created a C5 fanatic!!!
x 1865
I wouldn't count on buffed paintwork and leather massaging just yet!
That rusty chuck of suspension needs to be swapped for something solid.
Other side: same job (state of upper spring carrier as yet unknown, expect similar obviously)
That knackered auxiliary belt needs to be swapped.
Both the above are required ahead of Tuesday morning when my holiday is over.
Helping a friend nice house tomorrow (reckons he'll not need the C5 boot space, we'll see how fast the Transit Luton fills up :) )
.... And currently awake at 4 in the morning as my littlest is full of a cold :zzz: poor little chap
