Ah in that case I'd not tin it at all - and I'll let slip here I am an electrical engineer so I'm not just saying that randomly.
In the trade, you typically don't tin cables that will be screw terminal fastened, as it is thought that if an electrical fault occurred, heat could generate and melt the solder causing the termination to "let go".
However personally I know of another reason, something Jim touched on above, if you tin the end, you put more stress on the cores at the end of the tinned part, and this tends to cause the strands to fatigue and snap one by one. You don't seem to get this as badly when there are no tinned ends.
So I'd just twist the strands together, and then carefull fasten the screw down as centrally as possible over the bare end.
...of course it's your car, so you are welcome to ignore me and I'll not take offence
- and I know a lot of people tin the ends and have no trouble too.
