Reversing lights fault: (B) putting this down to the LED bulbs I've put in there. As per (G) car is happy they work - as are my eyes watching during above test.
Parking sensors: never worked as long as I've had the car.
Suspension faults are a bit odd, cleared will see if they come back.
Flow meter, cruise control, etc - it does knock the cruise control out semi regularly. If paused (having been in use earlier on same journey) when you come to "resume" via the pause button, instead you get a flashing " - - " and cruise control will not engage for rest of the trip.
Slight clutch slip at present if, sorry, when I am being heavy handed with the throttle. Did wonder if the engine speed Vs Road speed disparity during such slip events was behind some of the faults. But does not seem to be the trigger for cruise control falling over. Has never slipped when under the direction of the cruise control (as that tends to be gentle inputs obviously) only when I'm giving it some welly.
