Just a bit of info wanted, Am I right that you cant fit Bosch injectors on an engine with a Lucas/Roto pump, What happens if I do? Anyone ever fitted the 1.7 BX turbo engine into a ZX?
Cheers all
ZX 1.9d injectors
Depends on the opening pressure of the Lucas injectors (which are usualy a bit lower than the Bosch ones) and the pump timing, substituting a higher opening pressure injector for a lower pressure one will retard the injection timing slightly, this will cause a drop in preformance, assuming the pump timing is allready optimised for lower opening pressure injectors.
Dave
Knicker's, that reads wrong, meant that removing the lower pressure injector and replacing with a higher pressure one would retard the timing.
Dave
Translating DaveBurns very dense & informative answer :
Fit Bosch injectors with Bosch pump, and Lucas injectors with Lucas/Roto pump, - ONLY [;)]
Donno if the BX 17TD lump would fit in a ZX engine bay. Basically it's same engine type/construction, but a ZX TD engine would be a later development, possibly fitting a smaller engine bay space.
I think the most difficult part will be arranging for the ancilliaries drives. remember the BX has only an alternator driven off the front of the crankshaft, while the ZX has power steering as well and has a long belt with a tensioner pulley. The ZX also has a brake vacuum pump dreiven either directly or indirectly off the camshaft and I do not know if the drives are the same.
Much easier to use a proper engine for a ZX or have a look at a Peugeot.
having fitted a BMC diesel in a Land Rover many years ago I know that the most frustrating bit is getting all the odds and sods to fit and work properly. (engine in and out 3 times to get the clutch to operate properly etc)
Jeremy
Jeremy
