Citroen C3 Power Steering Issue
RDaniels72
- New User
Hello, I have a problem with the power steering in a citroen c3 1.4 petrol 2005. Namely, since a week when my wife turned the steering wheel as far as it would go, the power steering stopped working. I have checked the fuses and they are good, the controller which is in the battery housing is also good, the motor which is on the steering pinion is also good (when connected directly to the battery it turns). Hence my question is there still a steering sensor in it? If so, where? And it would be best if someone had a diagram of the power steering. Please help as I don't know where to look.
- x 6957
Re: Citroen C3 Power Steering Issue
There's not much you can do with these if it has packed up short of a replacement unit. The torque sensor is not sold separately - it's a complete unit. But I would first get a proper diagnostic with Lexia / Diagbox and when you do, pop the fault codes up along with the VIN, so we can get a better idea of the issue.
ozvtr
- x 251
How did you test that?
The steering system is usually fairly reliable.
Classic causes of failures are:
Loss of power in the charging system. Battery or alternator. How old is your battery?
Power to the steering, only left OR right. Torque transducer failure. This requires replacement of the steering rack.
The main power for the steering system comes from a "maxifuse" under the BSM (the fuse box in the engine bay). The pre-facelift cars were MF-8, sorry don't know which maxifuse is for the facelift models.
The big black 2 pin connector at the controller should have 12V there all the time.
