Another suspension pump issue?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Re: Another suspension pump issue?
There was (on Tuesday) a 57 reg C5 VTX+ 2.2l at Wokingham Car Spares. It has the Sport button on the suspension control. More than that I don't know, but I wonder if this would have a compatible pump?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5712
No they won't be the same. I checked and MK I & II systems are different.
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Marc,
Apologies I was referring to the HP pump not the BHI.
Kenny
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Again, I can't help you with the pump Kenny as they are not separate items and therefore have no PSA part numbers shown. I was just using the complete BHI references as comparison as these are complete with pump.
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Thanks Marc,
- My Cars: C5 2.2 VTR + Nav 173
Mazda 6 2.2 Sports Nav Estate
Jaguar 3.8 MkII 1961
Ex 2007 C5 2.2 Estate
Ex 2003 C5 2.2 Estate
Ex Xantia 2.1 TD Exclusive
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
@Kenny, thanks very much for your offer - a pity not compatible. @Hell Razor, good spot and would have been handy as our office is in Reading - not that I go there much these days.
@Marc, understood. I looked at the video you embedded and separation of the units doesn't seem to be an issue. I'm quite happy taking things apart (and sometimes even putting them back together correctly!), so my question is around the electro-mechanical aspects i.e. if I could obtain a second hand BHI unit from a Mk III, it might be possible to overhaul the electric motor and exchange, keeping the original pump and associated control. I appreciate that with no separate part numbers, it isn't possible to be sure about fit, but if the one I'm looking at is the right period I may take the punt as mine might be unrepairable.
As you said in a post in 2018, oh for the days of mechanical pumps and pullies. I could cope with those.
John
'59 C5 2.2 173 VTX+ saloon, Jaguar 3.8 MkII 1961
RIP - '07 C5 2.2 173 VTX+ Estate
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
There have been a few people I know of that have taken these apart (they do not need stripping down to the detail as in the video) and cleaned them. Have a look at Elis's illustrated post here, where he cleaned his pump out:
viewtopic.php?p=581404
- Donor 2023
- x 3007
57 reg is a Mk2.GiveMeABreak wrote: ↑15 May 2022, 22:00 No they won't be the same. I checked and MK I & II systems are different.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- x 3007
If the C5 in question is an X7 there is also one of those at Wokingham Car Spares, but I have no further information.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes I know that James I meant they are different to the OP's MK III X7.Hell Razor5543 wrote: ↑16 May 2022, 16:4857 reg is a Mk2.GiveMeABreak wrote: ↑15 May 2022, 22:00 No they won't be the same. I checked and MK I & II systems are different.
- citroenguy
- (Donor 2021)
- Lexia Available: Yes
- My Cars: Hobby car + daily: 1996 Xantia 1.9TD SX 84k miles
Past:
Citroën C5 I 2.0i 16V SX Saloon-04
Citroën BX16RS -88 stolen and burned :(
Citroën BX 19GTi -89
Citroën C5 II 2.0i 16v -05
Citroën ZX 1.8i 16V Break -96
2x Rover 620 Sterling
Rover 620Ti
Volvo 850
Various C5 and Xantia bought and sold - x 55
I have not tried it myself yet, but it is said to be only a couple of diffrent pumps. The pump outlets being the main difference, the pump ecu is transferrable.
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Exactly, and as the MK III has different outlets, it's best to keep the topic on the MK III.
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
I've made a start on getting the pump out. I changed the 40amp midi fuse and lowered the rear. Went to jack the car and noticed that the OSF jacking point was bent inwards. Given the very limited clearance it took much grunting, swearing and wishing I was younger, to straighten it. On lifting the OSF the jacking point started to bend again - cue much sweating and trembling. The car is now on stands, albeit not very high. Not having a Lexia, I started depressurising by bleeding the system from underneath. There are two accumulator (if that's what they're still called?) spheres at the rear, with a valve block and bleed nipple connected to them and I took about 1/3 litre out. However, the only extra front sphere I can see is on the NSF down low behind the engine and it looks pretty inaccessible. So, my questions are:
1. Is the front sphere behind the engine the one that needs bleeding?
2. If so, is it only accessible from underneath?
3. If I don't bleed it and decide instead to continue with the pump removal, could I just pop on some eye protection and use some of my scientifically proven ultra-absorbent special material (old underwear) wrapped around the pump and then remove the pipe unions, putting up with the mess?
The LDS reservoir is out and I'd really like to get to the next stage.
John
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
John,
The bleed nipple for the front is on the top of the offside sphere.
Also put your axle stands under the sub-frame where it is attached to the body. The lugs on the sills are only supposed to be used to jack the car for tyre changes using the scissor jack supplied with the car.
Kenny.
Kenny.
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
Thanks Kenny, I did wonder if the nipple on the offside was the one. I guess I'm just becoming more cautious in my latter years. The stands are indeed under the main subframe bolts, not the jacking points.
John
