I really don't understand what you're saying but the vertical height slider doesn't really work at the momentGiveMeABreak wrote: ↑01 May 2022, 14:44Assuming the motor inside the headlamp has not failed, then in the event that the directional function is disabled, it would maintain the height correction function - again as I indicated above: "only the headlamp dynamic height adjustment remains active" - which is the vertical up and down movement to prevent blinding of oncoming traffic.
Error light dynamic citroen c6 problem
Re: Error light dynamic citroen c6 problem
- x 3404
Ok in simpler terms, if the system detects a fault with either headlamp and in this example above with the ballast, then it means the headlamp goes into backup mode (refuge) where it will maintain the up and down movement (if possible) but will deactivate the left and right directional functionality.
This assumes the motor has not failed entirely and is able to move up and down.
GiveMeABreak wrote: ↑01 May 2022, 21:19Ok in simpler terms, if the system detects a fault with either headlamp and in this example above with the ballast, then it means the headlamp goes into backup mode (refuge) where it will maintain the up and down movement (if possible) but will deactivate the left and right directional functionality.
Thank you very much for your help and advice. Really the best thing would be to get a complete left headlight and test it to see if the fault is in the headlight or outside of it, but if it wasn't a problem with the headlight it would be a very expensive and unnecessary investment. I'll keep looking into the problem and see if I can get a headlight last.
