You're absolutely right! But combined with the fact that all the tests done with the Lexia came back ok, I'll say that this part if fine and I have to look elsewhere.Rhothgar wrote: ↑25 Apr 2022, 11:20Be careful measuring resistance with no load ie continuity. You can get continuity from just one strand of copper whilst all the others have corrosion around it and get a low reading providing you hit that clean core. It is always better to test a wire with a small bulb in series as that will load the wire and give a more accurate idea of whether the wire is fine.
Xantia idle problems
