Old school diesel question
'13 3008 1.6 HDi GripControl - x 1002
Re: Old school diesel question
There's another one, I think you can just see it on the second pic at the end of the RH arrow, this is the one you need the crescent wrench for...
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
Onlinemyglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Fits those star-shaped nuts perfectly.
- Donor 2023
'Old Katy'
myglaren wrote: ↑04 Apr 2022, 20:32
Graeme M
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I have refitted an overhauled pump back onto the engine simply by aligning the dirty marks, and it ran fine, I fitted a replacement (scrapyard pump) to an engine and it ran awful, i tried moving the pump a bit a couple of times but it was a massive pain in the arse and amounted to pure guesswork, I did learn that a tiny movement makes a huge difference, I would suggest getting hold of the gear and doing it correctly, it is not like tweaking a distrbutor a bit until it sounds sweet. and yes, I used one of those "access spanners" to get at the special bolt
- Donor 2023
'Old Katy'
Ace, well I have similar spanners on order now. Thinking about it, I can't believe I've had the diesel timing out all this time. I was aware the dimension would alter marginally but didn't think it would have such an effect. I mean only a few thou was skimmed off - really just to clean the face. I'll admit I didn't measure the piston tdc protrusion for gasket selection because my understanding was there no longer is a choice of gaskets and that only the thickest one was now available. In fact it might be that the dimension is oversized instead. That will have lowered the compressions a bit too. I think the retightening of the head bolts may have compressed the gasket further as well but it's likely still a bit over. If so the diesel timing might be a bit advanced instead of retarded. Anyway, it remains to be seen!
Graeme M
- x 31
Just re read this thread, when replacing the head gasket you only need to remove the HP fuel pipes to the injectors, head gasket replacement should not affect fuel pump timing unless you have stretchy conrods did you remove the pump to do the gasket ?
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
And me and the second photo on page 1 shows the head off and the pump in place. If it wasn't moved, leave it alone I'd say. The first photo's green arrow reminded me of something though........is the wax stat set properly? This can be tested very easily with your right boot lifting the revs to about 1100. My BX had a dead one for the last 2 years of it's life.Stewart(oily) wrote: ↑07 Apr 2022, 13:02 Just re read this thread, when replacing the head gasket you only need to remove the HP fuel pipes to the injectors, head gasket replacement should not affect fuel pump timing unless you have stretchy conrods did you remove the pump to do the gasket ?
Other than that, been as you've got the spanners, you can have a play with the timing if you wish. I'd just run it. At 132K it's about run in, I put 400K on a N/A one and it still ran like clockwork. As OldPug mentioned, they do clatter when cold, not an issue.
Pete
- Donor 2023
'Old Katy'
Hm in not sure about the wax stat. Certainly as it heats up the idle gradually quietens until its 'normal' sounding..
A light skin but a thicker gasket would increase the distance between the cam pulley and the crank pully by a tiny amount. And the distance between cam and diesel pump pulleys by an even smaller amount. But is this enough to nudge the timing a bit... well I'll make some micro adjustments when the spanners show up and so what happens.
Graeme M
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
What does it tick over at cold? The wax stat raises the revs to about 1100 (I think) then it should go back to normal when warm. It it's ticking over cold a little slow that will make it rattle more.
Pete
- Donor 2023
'Old Katy'
Hmm, now I think of it the cold tick over is under 1000 and more like 850 rpm
Graeme M
- Donor 2023
'Old Katy'
Ok! Well I moved the timing by about 1mm retarded and tick over seems to have increased rpm when cold. Does seem a bit smoother.
Graeme M
- Donor 2023
'Old Katy'
Thank you Richard for the spanner suggestion - ideal
Graeme M
- x 31
On a related not whilst rummaging in the garage I found a brand new wax stat fast idle unit, still in its packaging, heaven knows how long its been there, I will add it to my Xantia parts for sale thread.
