Thanks Marc
Nothing has been moved, it just failed to come on one day and there is voltage on F8 just not on the output for the radio. I think I am going to have to cut my losses and install another radio and satnav separately
Thanks to your connecting plug diagram I know which leads go where. The yellow permanently live lead is so I can connect it to that which means I can use it with the ignition off The only problem I can see is the different aerial plug, do they make an adaptor or do I have to fit a different plug?
I have come to the conclusion that this problem is almost insurmountable from what I have read but at least the car drives OK, even the aircon works! Thanks very much for all your help - hope I don't have to bother you again.
That pesky C5 X7 radio again!
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5719
Re: That pesky C5 X7 radio again!
I've provided you with the rear diagram and aerial designations along with the pin outs a few post back, so it all depends on what unit you are attempting to fit, but you should have all you need.
viewtopic.php?p=714034#p714034
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
Yes got those Marc, very useful, its just that I haven't seen that sort of connector before, will have a look on Ebay.
Just had a look, there are adaptors on Ebay.
