Finally success, as I suspected when I inspected the wiring to crankshaft sensor, there was a partially broken wire which I believe is the comms to ecu thus the signal voltage was away down hence fault.
Replaced plug with new and spliced in to the wiring loom. Working fine.
I have the old plug which I'm going to split the plug apart and re wire.
Kenny
Engine turning over but refusing to start
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Re: Engine turning over but refusing to start -FIXED
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
It's happened again working for 24 hours but different fault codes:
P0342 : Camshaft sensor permanent fault
Loss of camshaft signal while engine running
Variables associated with fault
Battery voltage 13.45 V
Camshaft - crankshaft synchronisation: yes
Engine speed : 1824 rpm
Coolant temp 77 C
mileage 239057
Acc pedal position 28 %
Vehicle speed at loss of sync :1824 rpm
Duration of starting command.
P0017
Starting monitoring
Sync time too long
I changed the camshaft sensor but left crankshaft sensor.
1. Should I but the original camshaft sensor back on and try again.
2. I'm going to do a bsi /battery reset.
Thoughts please
Kenny
Coolant temp 77 C
mileage 239057
P0017
Starting monitoring
Sync time too long
Thoughts please
Kenny
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 317
So to get it running you repaired/changed the crankshaft sensor plug and changed the camshaft sensor? If this is the case, why did you change the camshaft sensor? When working through problems I only change one thing at a time and if it doesn't cure it put it back to how it was (unless it's known fault).
Pete
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Yes Pete your summary is correct but on reading the fitting procedure for the camshaft sensor.I may have misread the instructions.
But I will change for the original and fit correctly as per procedure and see if that works.
Kenny
Kenny
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Fixed again put old sensor back in , did a proper BSI reset. It started fine.
Marc, Are there diagrams of crankshaft and camshaft 3 pin plugs with details of what each wire does and voltages associated with them
Kenny
Kenny
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 81
I have no experience with C5 X7 but reference voltages are normally 5V for sensors. Marc will no doubt be able to confirm.
Only briefly read through your post and fuel pressures seemed low especially the 77 bar. The fuel pressure regulator is normally pulse width modulation and 12V (switching on and off rapidly) to control the pressure. Pressure has to be achieved at cranking speed otherwise it will not fire. Downside is fuel pressure sensor could of course be reporting the wrong pressure to the ECU.
Open Cycle Ratio in Lexia for a working Xantia is 17-18% and that will be pretty much the same I would guess. Guesses down get cars up and running again though...
I see you mention can and crank synchronity issues too. It may be the more than one fault exists but all the you can if you do not have an oscilloscope is work with what you have got information wise! Sorry I cannot be of more help.
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Thanks Roger,
5 volts is what I found but my curiosity has got the better of me hence the question/request
Kenny
Kenny
