Hello PaulC5,
I see where you are pointing me, but the issue I am experiencing might be a little different. In the thread that you have sent the prolem appears for closing the door, while I cant get it to fully open. it opens ever so slightly, 10 cm from closed position not more and stops.
2009 Citroen C5 Tourer Exclusive electric tailgate functioning but not unlocking.
- x 6664
Re: 2009 Citroen C5 Tourer Exclusive electric tailgate functioning but not unlocking.
It really needs a proper diagnostic with Diagbox. Provide the codes and I may be able to assist you. I suspect that it's something your garage has done after you had the recent work done - maybe they force opened or closed it causing some damage. At this stage anything will be guesses without a fault code.
The electronic struts don't last forever and may need replacing - but again before replacing parts it needs a proper diagnostic.
